93 ls400 code 13 and 24
Old 06-18-12, 07:55 PM
chevelle71
chevelle71's Avatar
Default 93 ls400 code 13 and 24
My 93 ls400 started running bad today check eng light came on as well as trac light when i pulled the cods they were 13 rpm signal fault and 24 intake temp sensor not sure where to start neither are cheep parts can anyone help.
Old 06-19-12, 04:10 PM
deanshark
deanshark's Avatar
Your Air Intake Sensor, (code 24) is inside the Air Flow Meter and can't be changed seperately, need to change the whole AFM. That is also triggering the "trac off" light. It's pretty expensive new but you can pick up a used one at the junkyard for about $75, if ya can find one. If you need to run better "temperarely", you can unplug the AFM which will make the car run in Fail Safe mode. But dont run like that for too long b/c it will be running very rich.
Old 06-19-12, 09:10 PM
chevelle71
chevelle71's Avatar
Thanks Deanshark after doing an ohms test on the amf I found it was dead I started looking around there are a few toyotas that use the same amf unpluging it didnt help any but that was worth a shot thanks again for the input.
Old 06-20-12, 12:27 PM
steve2006
steve2006's Avatar
I think the early Toyota Supra uses the same AFM if you have this model over the pond.
Some here
http://www.ebay.com/sch/i.html?_trks...0+afm&_sacat=0
Old 06-20-12, 01:59 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
they don't. mk3 supra turbo guys use the LS400 (early) AFM to correct for sensor differences when using larger fuel injectors for increased boost.
will not work properly on your 1uz.
Old 09-02-12, 01:37 PM
shoob
shoob's Avatar
so would code 13 refer to the no.2 cam sensor?
dicer
02-19-16 05:45 PM
kaliboy562
03-26-14 08:22 AM
NyCrAzY
RX - 1st Gen (1999-2003)
06-12-12 12:45 PM
Seize
GS - 1st Gen (1993-1997)
03-30-05 11:53 AM
Quick Reply: 93 ls400 code 13 and 24
