ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   LS - 1st and 2nd Gen (1990-2000) (https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000-183/)
-   -   bendix/ starter won't stop turning (https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/598143-bendix-starter-wont-stop-turning.html)
fishguy55 Oct 17, 2011 08:26 AM
Yesterday I started my 1996 ls400, drove a few minutes then shut it off. HOWEVER, the starter kept spinning, at least part of it!! The key off ( & out of ignition) & it just kept going. Put the key back in & turned it to "start" & it did. Had to remove the battery terminal to get it stopped.. Removed all relays, & more but it kept going when I hooked the battery back up!! Any ideas?? A short at the starter or?
Thanks
steve2006 Oct 17, 2011 01:17 PM
It sounds like your solenoid plunger inside the starter has stuck so the contacts are closed all the time.
Looks like a complete strip down to replace the starter or repair the original.
billydpowe Oct 17, 2011 02:19 PM
3 Attachment(s)
steve is correct... I put new contacts in one of mine earlier this year, just pull the intake off and get after it.
the photos will show you where it is...
