Installing aftermarket amp/sub..
Old 06-24-11, 11:57 PM
DefendHI
DefendHI's Avatar
Default Installing aftermarket amp/sub..
does anybody know where i can run my wires through the trunk. is there a hole from the cab through the trunk?
Old 06-25-11, 12:48 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
through your 1979 cadillac eldorado?
please remember to actually tell us WHICH LS you have
and if you search you'll find a lot of answers.
Old 06-25-11, 01:34 AM
DefendHI
DefendHI's Avatar
my bad..1999 LS400
Old 06-25-11, 02:24 AM
fatcat2
fatcat2's Avatar
Originally Posted by DefendHI
my bad..1999 LS400
searching is your friend. anyway, on my 97 there were a few smaller holes where i was able to run my wires. just take off your rear seat, i believe its a 10mm in 10 spots for the back but cant remember. it was fairly easy to be honest. the hardest part was installing the actual head unit! now that is a whole different story.
Old 06-25-11, 06:29 AM
Kansas
Kansas's Avatar
There are fairly large holes leading to the trunk covered by tape that look a little like but are not grommets on the upper left and right behind the seat backs on my 2000 LS400. I used the one on the passenger side and ran wires from the trunk to the dash under the door sill covers.
In hindsight, I think it would have been much easier to have run the wires under the driver side door sill covers so I wouldn't have had to contend with routing the wires behind the CD changer and glove compartment or disconnect/reconnect the passenger dash mounted airbag.
Old 06-25-11, 08:45 AM
Rey
Rey's Avatar
Remove the back seats and youll see a plastic cover/grommet on the driver side where you can run it through. I recently ran 1/0awg through there no problem.
paulg123
10-13-08 08:52 PM
llcoolpass
14
04-07-08 06:57 PM
02Ku
11-15-07 06:08 PM
nthach
07-15-07 07:43 AM
vraa
02-03-05 09:14 PM
Quick Reply: Installing aftermarket amp/sub..
