refill the brake system
Hi, I have my brake lines broke and and all the fluid run of the brake system
I manage to put a new brake line and now I want to refill the brake system what should I do for the ABS and Traction refill can any one till me the procedure to refill the brake system, it is now has no brake fluid all empty thanks |
What year? This is for 96:
BRAKE FLUID BLEEDING HINT: If any work is done on the brake system or if air in the brake lines is suspected, bleed the system of air. NOTICE: Do not let brake fluid remain on painted surfaces. Wash it off immediately. 1. FILL RESERVOIR WITH BRAKE FLUID Fluid: SAE J1703 or FMVSS NO.116DOT3 2. BLEED MASTER CYLINDER HINT: If the master cylinder has been disassembled or if the reservoir becomes empty, bleed the air from the master cylinder. (a) Disconnect the brake lines from the master cylinder. (b) Slowly depress the brake pedal and hold it. (c) Block off the outer holes with your fingers, and release the brake pedal. (d) Repeat (b) and (c) 3 or 4 times. 3. BLEED BRAKE LINE (a) Connect the vinyl tube to the brake caliper. (b) Depress the brake pedal several times, then loosen the bleeder plug with the pedal held down. (c) At the point when fluid stops coming out, tighten the bleeder plug, then release the brake pedal. (d) Repeat (b) and (c) until all the air in the fluid has been bled out. F12081 SST F12082 BRAKE – BRAKE FLUID BR–5 Author: Date: 1389 1997 LEXUS LS400 (RM514U) (e) Repeat the above procedure to bleed the air out of the brake line for each wheel. Torque: 11 N·m (110 kgf·cm, 8 ft·lbf) 4. BLEED BRAKE ACTUATOR (a) Remove the reservoir cap. (b) Install the SST to the reservoir. SST 09992–00241, 09992–00350 (c) Connect the vinyl tube to the bleeder plug of the brake actuator. (d) Using SST, apply the pressure described below to the reservoir. Pressure: 98.1 kpa (1.0 kgf/cm2, 14.2 psi) (e) Loosen the bleeder plug. (f) Bleed the air out of the brake actuator, tighten the bleeder plug. Torque: 8.3 N·m (85 kgf·cm, 74 in.·lbf) 5. CHECK FLUID LEVEL IN RESERVOIR Check the fluid level and add fluid if necessary. Fluid: SAE J1703 or FMVSS NO.116DOT3 |
sorry it is Lexus Ls400 1993 , what about ABS and Traction how to get the air out of it as the reservoir and the lines has no fluid all run out , does the ABS and traction need to remove air out of them too and how? any images please
Thanks |
is there a way to work without the SST 09992–00241, 09992–00350 I dont have it where I get it from I am in Canada- Ontario
Originally Posted by haroun
(Post 6454126)
so what about the ABS ? bleeding?
this qualifies as one of those things that if you have to ask so many varied questions you probably should let someone comfortable with the procedure do it or show you how...
