What type of oil do you use? (The Mother thread)
Old 03-25-14, 12:31 PM
  #286
LScowboyLS
LScowboyLS's Avatar
Originally Posted by blumonster
0w-30 Castrol . For some reason in WI winters, engines are quieter with this combo.
even people who live in the 130 degree Arizona desert or in Miami or Dubai should use 0W-30 in their LS400 for maximum engine life.
I know, it seems crazy, until you read Motor Oil 101 at BobIstheOilGuy.com, where the world's oil gurus hang out
The greatest confusion is because of the way motor oils are labeled. It is an old system and is confusing to many people. I know the person is confused when they say that a 0W-30 oil is too thin for their engine because the old manual says to use 10W-30. This is wrong.
Old 03-26-14, 05:32 AM
  #287
python
python's Avatar
newer high end bmw's (M-series) use 10w-60 and liqui-moly is recommended..one of the best oil on the market
Old 03-26-14, 03:02 PM
  #288
xxmariolxx
xxmariolxx's Avatar
i put mobile but next time i change the oil it will be mobil 1. i just wanted to make sure there are no leaks since i just bought the car about a month ago
Old 03-26-14, 06:11 PM
  #289
LScowboyLS
LScowboyLS's Avatar
Increasing the pressure while using the same oil will increase the oil flow but increasing the pressure by increasing the oil thickness will result in less flow. It takes more pressure to move a thicker oil. When you go to a thicker oil the pressure goes up because of the increased resistance, and therefore reduction of flow. Because the pressure is higher sooner, the relief valve cuts in sooner. Flow will actually be less when the RPM is up and the flow is needed the most.
I can't wait until Toyota back-specs our LS400's for 5W-20 or even 0W-20
Old 03-27-14, 05:13 AM
  #290
python
python's Avatar
the thicker oil has an effect on sheering..nothing to do with pressure. they never will back spec these cars and what difference does It make..run whatever oil u want.
also why would they back spec on these cars which run over 300,000 miles regularly? if it aint broke.....
Old 03-29-14, 11:32 PM
  #291
aptoslexus
aptoslexus's Avatar
If you use Pennzoil Platinum here's an oil deal for you. Oreilly has a "buy 5 quarts of synthetic with a Bosch filter for $34.95" deal going this week. They have a $10 Oreilly card rebate on the deal which you can use twice. On top of that, Pennzoil will give you a $1/gal price break on Shell gasoline at participating stations on up to 20 gallons of fuel. http://www.pennzoil.com/promotions/#&panel1-1
So you throw down $70 for 10 quarts of Pennzoil Platinum and you get 2 $10 Oreilly Cards and two trips to a Shell station saving a buck/gallon on up to 20 gallons. Basically, that's about $60 maximum back into your pocket.
Old 03-30-14, 12:30 AM
  #292
LScowboyLS
LScowboyLS's Avatar
Toyota has indeed back spec-ed a large number of models over the years, to thinner, more modern oils, I have posted the chart of these new oil guidelines before, but here it is again, for those who missed it.
Old 03-30-14, 10:08 AM
  #293
python
python's Avatar
a lot of those cars on the list have issues with engine sludge and none have the same engine or the reliability of the ls 400..apples and oranges
Old 03-30-14, 10:47 AM
  #294
blumonster
blumonster's Avatar
I would choose 5W-40 version of Ultra. Amazon has it for around 35 for a case of 6. You can still get 1 dollar a gallon off Shell gas.
If anybody is interested in 90915-20004 filters please let me know. I won't be needing them the way it is going.
Old 03-30-14, 12:04 PM
  #295
dc893
dc893's Avatar
Why would you choose the 5w-40 of the Ultra?
Old 03-30-14, 10:24 PM
  #296
blumonster
blumonster's Avatar
It is a long drain interval oil, carries BMW, Benz, VW approvals. European origined. 'Rare'.
Just got, for the first time, Castrol 0W-40 oil for $25 from WM. 5qt bottle. Next I will try that.
I change oil rarely before 8k miles, most of the time I change after 10k miles if I drove mostly highway.
Old 03-31-14, 06:10 AM
  #297
python
python's Avatar
so it has the 502 spec or the bmw LL04? your car doesn't need that.
Old 03-31-14, 09:18 AM
  #298
LScowboyLS
LScowboyLS's Avatar
again, all of you fellows debating this really need to stop and take 10 minutes and read Motor Oil 101 at BobIsTheOilGuy.com - it will dispel all of these old myths about how thicker oil is better, and uses science from petroleum and automotive engineering to explain it where even non-engineers can understand!
Educate thy self!
from the course:
Old 03-31-14, 11:40 AM
  #299
Finn
Finn's Avatar
There is a difference between oil viscosities recommended and used in US and Europe. Where 5W-30 is put in just about any vehicle on your side of the big pond the 5W-40 has been the mostly used viscosity as long as I can remember. The newer cars of course get thinner oils also here.
Old 04-01-14, 05:15 AM
  #300
Finn
Finn's Avatar
Some of this is going in my LS next time:
Quick Reply: What type of oil do you use? (The Mother thread)
