Advice on Lexus LS400 Catalytic Converter
AlaskanLS ... may I suggest to check and see if your coil wires are ok?
As for me, I had one on the driver side short out against the block ... it had been rubbing there for years ... I had no idea this was the case. I was able to do a temp repair on the wire and get the car going again .... however I ended up driving the car for way too long with the busted coil wire, thus dumping raw fuel through the exhaust and thus screwing up my cat on the driver side. I parked my car and stopped using it. Now I am finally getting around to fixing it all up .... so I also need some new cats; in this case I have to buy some that are legal in California.
I wonder what is the highest quality after market unit available? I have no idea, but maybe we can get lucky and someone will chime-in on this ... it sure would help. If it was any other car it probably would not matter so much .... but geeeze ... give me a break ... the actual Lexus replacement is insane, crazy expensive -- -- -- $$$$$$
Anyways ... I would for sure be checking your coil wires .... if I am not mistaken it is actually possible to buy just a single coil wire from your dealer .... if needed.
I wonder what is the highest quality after market unit available? I have no idea, but maybe we can get lucky and someone will chime-in on this ... it sure would help. If it was any other car it probably would not matter so much .... but geeeze ... give me a break ... the actual Lexus replacement is insane, crazy expensive -- -- -- $$$$$$...
BTW, good call on the ignition coil wire - you were right.
bsteinbach
05-04-06 06:47 PM
