Will Poly Sway Bar Bushing, Reduce Sway?
01-05-14, 02:16 PM
Will Poly Sway Bar Bushing, Reduce Sway? If so, what is the size of the dang bars? Come on people, i know someone has measured the ucf20/21 sways bars, right?
01-05-14, 02:20 PM
Yes and it can create unwanted noise. I only know of the ones for 1st gens from daizen.
01-05-14, 09:41 PM
BahHumBug
ever so slight improvement over good stocks, massive improvement in felt "tightness" over worn stocks.
buy energy susp. universal ones that are the right size and have grease fittings. previous threads on this, search and read the FAQ.
01-07-14, 02:46 PM
BRO, i have seen the old treads, but therefore 95-97 models. i have a 98-00 model, I need answers, don't you?
01-07-14, 06:22 PM
Aren't they the same size? I just punched in the part number for the front and rear sway bars into a Lexus parts catalog and it says they use the same part number from 95-00, unless I am mistaken?
01-08-14, 09:57 AM
correct, 95-00 have the same sway bar sizing.
tightness will increase ever so slightly, just make sure you lube them properly or they will SQUEAK! also check your end links as well.
01-08-14, 01:37 PM
BahHumBug
Quote:
Originally Posted by
timmy0tool
actually no, they are a bit different on usdm cars.
'98-00: 48812-50100
'95-97: 48812-50080
Fronts:
'98-00: 48811-50080
'95-97: 48811-50050 (non a/s)
'98-00 in my experience are a bit thicker.
01-08-14, 02:01 PM
good to know! too many variations between models i tells ya!
Caflashbob
12-11-16 09:24 PM
Rock-a-Lex
Suspension and Brakes
10-15-13 09:10 PM
PHML
28
09-26-13 06:02 PM
NEbiker10
SC- 1st Gen (1992-2000)
04-22-11 11:56 AM
LexAnt
07-27-04 03:53 PM
