'98 LS 400 Right Rear Power Door Lock Problem
1 Attachment(s)
Hello All,
The right rear power door lock on my LS does not work using the FOB or the main control on the driver's door. I can manually lock and unlock the door with no issues and it looks like all mechanics in the locking process are working as they should. I have the door panel removed thinking it is the door ECU (the silver rectangle with a bracket attached to the door on the right hand side). Has anyone seen this problem or can comment on what the problem might be? Thank you. Eddie |
The actuator is probably dead. Any sound from it when you lock-unlock?
Thanks for your prompt reply.
Do you mean the Door ECU in the picture? Is the actuator behind the piece of clear plastic? Eddie EDIT: Yes, I can hear the actuator. If I put down the window, I can see the actuator and it feels (used a long screwdriver to touch it and I feel vibration that way) and sounds like it is working. Whatever happens, I'll post my solution to the problem.
Originally Posted by RA40
(Post 5511035)
1 Attachment(s)
Here's the actuator the best I can tell. It's the black object with the blue shrink tube going to it.
It sure seems like it is working and is a bear to remove. I removed the two silver bolts at the end of the Door ECU bracket and that thing is barely moving. Stay tuned... Eddie |
My 99 LS left front actuator is dead, all others lock & unlock, trunk works. JUST LFD..
but I wont pay the 300+++... |
oh yeah, it comes with the lock.
Just an update in case anyone is interested. I called a local salvage yard today and they wanted $150 for a lock/actuator from a '98.
I passed as it seemed steep for a 12 year old part. Under $50 and I prolly would have rolled the dice. Eddie |
go search the 2GS forums, they have theirs go out and fix them for cheap using normal small 12v dc motors.
look for "door lock actuator" |
