93 LS400 engine miss
Old Nov 22, 2009 | 09:14 AM
duncan351's Avatar
duncan351
Possibly a bad injector but sounds more like a spark problem. You'll have to pull the park plug covers off on each bank but check wires including the coil wires. Make sure you don't see any spark arcing. Even i they are just replaced.
Old Nov 24, 2009 | 10:29 AM
viper.boy's Avatar
viper.boy
Try disconnecting the EGR valve's electrical connector. It solved the engine miss and surge problem on my '93 without any negative side effects. The EGR is bolted to the driver's side of the intake manifold and is black and round with a large, horizontal electrical connector.
Old Nov 24, 2009 | 11:03 AM
CrashGT007's Avatar
CrashGT007
the check engine light is supposed to come on when the key is in the on position because its not getting a reading from you cam and crank sensors but when you turn the key to start the car it will turn out... its the car checking its self so dont go through the hassle of pulling the panel. the cam and crank sensors send a signal only when the engine is running so when the engine is off it thinks it has a problem but its not.
Old Dec 2, 2009 | 03:57 AM
vaughn37's Avatar
vaughn37
I don't have the egr system on my car i took it off..and i put resistors in the connectors to keep from getting a engine light.. I do know my wires and caps are original so maybe this is the problem.
JohnyUtah
Sep 6, 2022 02:07 PM
619miller
Nov 30, 2015 07:13 PM
waqas300
Jul 13, 2015 12:43 PM
