help! turnsignals light bulb
ok i have a 1999 LS 400. how do i get to the lightbulb front turnsignal. the lightbulb died out and im trying to change it out but it looks complicated to take off. need some help thanks...
Open the hood, remove the one screw that holds the turn signal housing in place, pry the turn signal housing out by grasping the forward edge (between the headlight lens and the turn signal lens) with your finger tips -- same procedure as for removing the non-turn signal "city light" housing on the 90-97 LS400.
Be gentle but firm -- it is easy to crack the plastic lens when the 90-97 city light and 98-00 turn signal ages and becomes brittle. |
