How to fix powersteering leak on 98-2000 LS400's
#76
@djamps Is the ACDELCO PS Pump still going strong? I am planning to chip in for mine. So looking for some good reman's
#79
Well I did the rebuild thing (o-rings and bearing), it took up a lot of my time mainly just to get the bearing out, once I put everything back together again it started leaking more than before so I simply replaced it with a reman and its been doing great for the past 7 years or so. Btw, I'm using remans on both my '98 and '95, still going strong, no issues. I'm usually up for the challenge of rebuilding things, but this was a no-brainer just in terms the time savings. Good luck.
BNastee (06-21-21)
#80
Reviving the old thread. I just received 1998 LS400 that needs some fixing and power steering pump is one of them.
I keep going back and forth between:
1. Buying remanufactured/rebuilt pump
2. Buying new OEM
3. Rebuiding existing pump
Most of the posters, other than replacing with new OEM pump, seems to experience one leak or another in a very short time.
I'm really interested in just replacing O-rings, if this does really work.
Anyone can share their experience?
If you went to remanufactured/rebuilt pump, which brand did you go with? Majority of the posters experienced issues after install.
Thanks in advance.
2. Buying new OEM
Thanks in advance.
Too many horror stories on the rebuilt pumps now,dont go that route,same story on any china rebuilds,alt,starter,just freaking pure junk.I had three dead alternators on my truck in a row,the third one caught fire!! From carquest about 2-3 years ago.Nephew had 3 bad starters in a row on his jeep.
Pay the money and get the OEM,or if you are clever,rebuild it yourself.ONLY options IMO,FWIW.
#81
The oem pump is 44320-50030. I got mine for 411.00 dollars from Longo Lexus.With tax and shipping was 455.00 dollars.
I put in AC Delco rebuild from RockAuto and it has been a year and 13k miles now, seems still solid.
spuds (08-30-20)
#82
If you have a leak, but it still hasn't killed the alternator, would it make sense to replace it?
The car has 200k miles, I just bought it and it was leaking when I got it. Who knows how long it had the leak for. The whole engine is full of oil dirt grime lol, I gotta clean it..
But the car has worked for the month I've owned it. Drove it over 1k miles with no problems, it just had the leak but nothing happened.
Now I'm doing the timing belt and wonder if it's worth replacing since I'm there. Or should I just leave it since the car still works?
#83
I would not only replace it I would upgrade to the ls430 alt,denso rebuild is about 230 dollars,its a beauty,looks brand new.Many threads for alt upgrade here.You need to buy an extra bolt for it.I also made a cover for mine.For ME,I would do it all at once,cant hurt putting on new OEM/denso rebuilt parts.So,whats your budget I guess will determine route you take.Good luck,and beware the serpentine belt tensioner,it righty loosy,lefty tighty.Do that wrong and cry,BTDT.
#84
#85
As for the cleaning of the oil grime, does it matter what I use? Any recommendations on what to use? I got Simple Green on hand, or is that a bad choice?
Also, when I removed a pulley, it had a bit chipped off. Does that make a difference? Or should I just keep it? They did the timing belt at 90k, 110k miles later and it's been there. I'm assuming it's safe to reuse, but I don't know how sensitive these things are.
That's the bit that chipped off. I'm assuming it's nothing important.
Also, does the alternator look in good condition? I'm assuming when they go out, they're drenched in ps fluid? Like I can, the car starts still no problem. Thanks
#86
That alternator looks pretty new. I wouldn't even think about changing that. (spend the money elsewhere) They must have changed it cuz of the PS leak. It might have been one of their last repairs before selling the car. I would definitely fix the PS leak so it doesn't kill that alt. While you're changing the T-belt and cleaning up the grime, you should look to see where any other oil leaks are and fix those while you're in there. The valve covers are known to leak from loosened bolts over the years which, most of the time, can just be tightened down (not too tight) to stop the leak. Which pully are you talking about that has a chip in it? It'd be nice to also see a pic of that so we know which one and how big or small of a chip it is.
ls400newbs (06-22-21)
#87
It's actually the one in the picture lol.
It's a tiny chip I suppose, on one of the walls(?) of the pulley. The back one. You can see it in the picture, the pulley on the left, it has a little rust spot at around 2 o'clock I think. The chip is about 3/8" wide at the most. I didn't hear no noises from the belt while driving. I'm just trying to make sure I'm not missing anything
BNastee (06-25-21)
#88
What's the reason you said not to use type iv atf and just regular atf? That has me confused. I remember reading that the car calls for type iv in the ps system.
#90
This bit should clarify the question for you.
My experience on a pump replacement and flushed completely NOT using Dexron III but synthetic which doesnt work,It buzzes/whines.Done on a new OEM pump from Lexus.
EDIT-Actually Im NOT happy with the synthetic Valvoline fluid.There is still a very slight buzzing and even my stinky brown Dexron II or III mineral ATF did a better job.I couldnt find Dexron III locally so find out the plain Toyota ATF is dexron III.So go to Toyota,he doesnt have it,we use STP,and they dont make Dexron III any more.So show him Toyota part number,he looks it up,Oh,they do make it but we dont carry it.So get him to check other places,one has like 66 qts of the stuff.Wound up just ordering 4 qts off ebay and cheaper delivered than Toyota.Will get that changed,it wants dexron III and thats what it will get.
Yup,mine had a nasty buzz with the synthetic that didnt get better but actually got louder,thats not good.This was a pump change and complete fluid change with synthetic.Car calls for Dexron III.Ive no doubt you can top off with synthetic and its compatible as in it wont hurt it and probably be just fine,as in a small amt no problemo.
BUT,complete flush it will buzz like bees.I flushed with Toyota ATF and it quieted right up after a bit of driving and now functions nice and quiet like it should.
So I flushed with this stuff,TOYOTA AUTOMATIC TRANSMISSION FLUID. In the black qt container.Says right on it "Formulated to replace Dexron III in applicable Toyota models.Make sure you get the right fluid that says right on it its the dexron III replacement,with net research shows it is Dexron III and further people use it in the Dexron III Toyotas that call for it in power steering with perfect results.
https://www.clublexus.com/forums/ls-...ing-noise.html
Toyota Genuine Automatic Transmission Fluid.
The premium ATF specifically designed for Toyota automatic transmissions
Attachment 486572
Attachment 486573
__________________
Attachment 486572
Attachment 486573
__________________
The following 3 users liked this post by spuds:
