New owner(94 LS ) Reporting in.
Old 11-06-08, 05:01 AM
Scorny
Scorny's Avatar
Default New owner(94 LS ) Reporting in.
I just picked up a 94 LS with 131 miles on it and I couldn't be happier....
The guy I bought it from said a few things have been changed not including water pump and timing belt but the rest he had reciepts to show for it.
I took it to the dealers and they were able to confirm the timing belt was changed around 90miles ago.Without compromise as per you guys and the reading I've been doing,I'm gonna go ahead and change the water pump,timing belt,thermostat,do oil change and what else....guys ?
The gentleman I bought the car from had the tach rebuilt(had reciept) but lo and beholhd,the needle has just stop lighting up and cant read the miles at night....From my research here,it looks like thats a common problem with these cars.Everything else lights up.
The airbag light is on,so is the brake lamp(front pads are worn) and the trac OFF and check engine lights comes on and off once in a while.
I will appreciate any help,tips from you guys,Thanks.
Old 11-06-08, 12:56 PM
tcbted
tcbted's Avatar
Very nice looking ride.
When I need major servicing, I use Bullock City in Markham. Its run by a Lexus Tech,
but much cheaper labour rates.
They did my t-belt and wp, plus a few other parts, for around $600, using OEM parts.
You might want to look into a good set of snows ... even with 4 snow tires, I had some
pretty scary moments with all that snow we received last winter.
Good luck with your car.
Old 11-06-08, 01:33 PM
black_LS
black_LS's Avatar
Scorny,
Nice car, congrats.
tcbted,
I have to install engine mounts, upper control arms, strut rods, lower ball joints, and coilovers. Do you think he can handle that for a reasonable price?
Thanks
Old 11-06-08, 01:37 PM
Scorny
Scorny's Avatar
Thanks for the tip tcbted.I'm gonna email andy and see if he can give me a quote.
Old 11-06-08, 03:58 PM
tcbted
tcbted's Avatar
Black LS, I don't see why they couldn't handle your job.
Its a large, well equipped shop. Andy is a Japanese trained Lexus tech ... he worked at
Don Valley Lexus for many years.
Check out his website ... by the way, I was impressed that he actually test drove my car before and after my repair, double checking my fluids after the repair.
http://www.bullockcity.com/aboutus.html
Take a virtual tour of his shop ... cleanest I've ever seen.
Old 11-06-08, 05:01 PM
SH212
Dances with goats
SH212's Avatar
nice pick up and welcome to CL
Old 11-07-08, 06:00 PM
Rocan
Rocan's Avatar
great car bro... i have the same year and color... why would you have the timing belt replaced if they just did it 90 miles ago?
Old 11-07-08, 09:24 PM
SH212
Dances with goats
SH212's Avatar
i think he means 90,000 miles ago
Old 11-07-08, 11:09 PM
Rocan
Rocan's Avatar
ahh... that would make more sense
Old 11-08-08, 05:38 AM
Scorny
Scorny's Avatar
Here's the quote I got from bullockcity.What do you guys think,is it about right ? All OEM parts and the funds are in Cdn mulla.
Timing belt $97
Water pump $245
Coolant $21
Idler bearing $125
Tensioner bearing $199
Cam seals $20
Crank seal $12
Labour $495
$1214+tax=$1371.82
Old 11-08-08, 05:02 PM
steveski
steveski's Avatar
Welcome to CL - very nice first gen - clean
Old 11-09-08, 03:05 PM
tcbted
tcbted's Avatar
Scorny, I know that service list adds up pretty quickly.
Keep in mind that Andy has more Lexus experience than most dealer techs.
That list of parts and labour would be higher at any Toronto dealer.
Once he's in there, you might as well replace all the smaller parts.
This service will give you years of worry free motoring, knowing it was done right
with OEM parts.
Good luck.
Old 11-09-08, 04:23 PM
Bradster
Bradster's Avatar
Parts are way too high...Go to http://www.trademotion.com/partlocat...?siteid=214082
I'm sure you'll find someone that will ship to Canada if the above doesn't..
Old 11-10-08, 11:54 AM
Scorny
Scorny's Avatar
with OEM parts.
Good luck.
Thanks.What other parts will you guys recommend changing? I'm taking her in on friday and since I have the funds to at least get her done now,I might as well.
Once the money is gone,its back to the 'hard to work overtime hours'.
Old 11-10-08, 12:07 PM
LiCelsior
Retired
LiCelsior's Avatar
heres how to read the codes, http://www.lexls.com/tutorials/intro/codereading.html
www.lexls.com is a major major website for LS owners..mostly 1gen but helps 2gen guys also.
Quick Reply: New owner(94 LS ) Reporting in.
