Whats wrong with my headlights>
The inside headlight beams, the yellow/orange ones, one both sides are not working. I did not even know they were there until I saw another lexus with them on. I checked a fuse box under the hood and the fuse box under the driver-side dash. All are ok and the bulbs both look fine. I also noticed that the rear interior lights are not turning on when the doors are opened. I am missing something? Sounds like a fuse but I think I checked all of them. Any help??
The interior lights in the first gen LS are known to go bad (the wiring goes bad).
You can turn on and off the yellow on your light switch. It is a little further the turn signal stick.
Originally posted by petrojeff
The dome light and driver and passenger foot lights are not working with the door switch in my LS400. I also have no stop lights on my rear hood mounted combination lights. I have checked all the bulbs and they are good. I found that I do not have continuity on one of my wires from the stop light to the light sensor relay. Anyway, my question is..Where in the harness does the wiring go bad?
Originally posted by lextek
Do your interior light work when the passengers side door is open?
