Replace shock/strut mounts??
Old Aug 31, 2004 | 12:10 PM
W Lee's Avatar
W Lee
Default Replace shock/strut mounts??
My LS400 has 100,000 miles on it and I am about to swap out the springs and shocks... is it worth the time and money to replace the mounts? Will I notice any difference in ride quality?
Old Sep 2, 2004 | 11:38 AM
RA40's Avatar
RA40
Super Moderator
If the mounts are new, then this will be the time to replace them. Unfortunately, you won't know till you've removed them from the car. As for ride, a new insulator will mainly help to provide a level surface for the spring to seat on. The biggest change wil be the struts and springs depending on what you install.
Old Sep 7, 2004 | 03:56 PM
damon's Avatar
damon
Default Mounts
If you are using OEM parts and are not deterred by cost I would go ahead and do it. I would only use OEM for this though. I changed just the front upper strut assembly on my 94 ( along with the new f&r oem struts) at 143,000 miles. They mounts actually appeared to be in pretty decent shape.
Glad I went ahead and did it though because I think the ride is pretty smooth for 161,000 mile + vehicle.
nomad
Bix49
May 6, 2015 04:03 AM
99custom
Sep 7, 2014 06:25 AM
4evDev
Oct 6, 2012 08:24 PM
suraj83
Dec 6, 2011 07:37 AM
Sportznuts
17
Aug 23, 2008 01:36 PM
