upper control arm?
Old 05-04-04, 06:33 AM
blkstealthpaid4
blkstealthpaid4's Avatar
Default upper control arm?
I do remember when I had upper control arm problems I bought one from the yard.I could remember the car would make clunking sounds when I was turning into a curve and braking at the same time.Another symptom was that when my mechanic shook the wheel as if to check the tire rod, the wheel had play in it.This is why I am doubting the upper control arm.I hope a supension shop can find this out.The car also fishtails when I go over bumps and I think this has something to do with the rear suspension.
Old 05-06-04, 06:34 PM
stelios
stelios's Avatar
your best shot is take it to a good mechanic or even better the lexus service center. Good luck
Old 05-06-04, 07:33 PM
persian451
persian451's Avatar
rear sway bars need to bushings.. or rear carrier bushing, i think they are the same thing
Old 05-07-04, 07:55 AM
blkstealthpaid4
Default sway bar for the rear?
I think you are right about the sway bars for the rear.Is the sway bar or the carrier the bar that the struts sits in between?Or is it the V shaped bar which is mounted on the body of the car while the other end goes into the bottom of the spindle?I will test both upper control arms (front)on both sides and also replace the bushings for the sway bar(front).I did also replace the strut bar after hearing that clunk sound.It pays to be a DIY person.
Could you please tell me which one is the sway bar for the rear in this pic?Are the bushings sold separately?
https://www.clublexus.com/forums/sho...hlight=bushing
Is it # 3 in the pic?
Old 05-07-04, 08:29 AM
persian451
persian451's Avatar
yea i think that's, theres a guy that makes bushings for the rear for a good price...
check out this thread...
https://www.clublexus.com/forums/sho...rrier+bushings
i think lvangundy might help you out more... hes got more info on this than me
NoahAA
12-22-17 11:02 AM
DA51
Suspension and Brakes
14
11-22-16 08:35 AM
dealer374
03-29-10 02:16 PM
white ice
01-22-06 10:14 PM
Quick Reply: upper control arm?
