Diagnostic Code?
Check Eng.Light On. It actually come on and goes off randomly during normal driving conditions.
DIAGNOSIS: Using a paper clip to bridge the E1 and TE1 ports on the diagnostic box under the hood, then turning key on but not starting car, I get the Check Eng Light to flash 2x then 5x.{ __^^___^^^^^___} Does anyone have a factory manual that can tell me what code this is and what to do to fix it. I recently had my Catalytic Converters replaced so I feel this may have something to do with O2 sensors but not sure. Let me know thanks Kaiser |
read these threads
edit; here's an even better one https://www.clublexus.com/forums/sho...hreadid=111481
https://www.clublexus.com/forums/sho...ine+code+LS400 |
that is code 25, change your front 2 o2 sensors.. i got the same code.. and it went away after cahnging the front 2 oxygen sensors
www.batauto.com explains the meanigns of the codes. |
