LS400 Shifting problems
Old Sep 27, 2025 | 06:33 PM
Wmidulla's Avatar
Wmidulla
1st Gear
Default LS400 Shifting problems
I have a 1999 LS400. When the car sits for any period of time and I place it in drive, it doesn’t shift into first gear until the engine warms up. Has anyone had any similar problems?
Old Sep 30, 2025 | 10:47 AM
timmy0tool's Avatar
timmy0tool
i moved this from the build sub-forum to the main forum for better traction!
to your question, i would check the transmission fluid level! low level will cause the issues you are describing. when it gets hot the fluid expands and thus rises then engages the gears. i recommend using toyota type-IV ATF only!
note: on the transmission dipstick, there is a COLD side and HOT side. it's better to use the HOT side - and check the level while the engine is running on a level surface (when the car is warm obviously ).
Old Sep 30, 2025 | 07:32 PM
Yamae's Avatar
Yamae
+1 for the low ATF level. Sometimes the low oil pressure causes the problem especially when the strainer is clogged.
Old Oct 1, 2025 | 12:09 AM
dwoods801's Avatar
dwoods801
Doesn’t shift into first until it’s warmed up? My 99 GS400 never shifts into first unless I pull the shoft lever down into first gear. Does you car not move until it’s warmed up? Or it just feels extra sluggish when it’s cold? And maybe it’s always starting in 2nd gear?
director
Performance
Feb 13, 2019 12:06 PM
zzr600
Aug 20, 2014 06:34 PM
dougie23
19
Jan 16, 2012 08:03 AM
Stage3
Jul 20, 2005 09:59 AM
