DLR's???
If there is a way to make DLR's run at full voltage making the lights white would you guys still want to disconnect them??????????
the reason why the are yellow is because they are running at 50% power(or somewhere around there) if you want them to run full power just flip on the high beam switch( which would be pointless). only option i can think of is disable the DRL. that way your high beams will still work when you need them. there is no halogen light bulb you can replace that will look white on that low of power.
| All times are GMT -7. The time now is 02:56 AM. |
