ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Lighting (https://www.clublexus.com/forums/lighting-128/)
-   -   HID Kit and DRL LED's (https://www.clublexus.com/forums/lighting/917959-hid-kit-and-drl-leds.html)
silva1181 May 6, 2019 09:04 AM
Good morning!
If all goes accordingly to plan I will be picking up a 2011 base model ES350 later today. I do not plan any major changes for the car other then some tint and lighting, specifically the halogen bulbs.
I have a set of the following lights that I just removed from a newer 4Runner which are the same type of bulbs the ES uses but want confirm there are no issues with using these in the 2011 ES. I sure I am fine, but thought I would check
lo-beam - H11 Xenon Depot HID kit.
DRL / hi-beam - Xenon Depot - 9005 Xtreme LED kit with module for DRL/high beam.
Thanks,
silva1181 May 6, 2019 12:52 PM
I found what I needed.
ericwudi08 Jul 10, 2019 04:30 PM
Nice did you end up going with the brand above?
silva1181 Jul 15, 2019 06:48 AM
Yes, I did. Both work and no issues with the DRL or hi beam, although the light for hi beam isn’t good compared to halogen bulbs but I knew this. I doubt I will ever use the hi beams so not worried about it.
S2kstephen Aug 27, 2019 09:52 AM
XenonDepot makes top-notch parts - great choice.
