07 ES350 DRL/High Beam Aim
Hello,
I have read through several posts regarding the headlight / high beam aiming. I understand that the aim of low or high beam is done with one adjustment and that there are not separate adjustments. In my case, the drl/high beam is out of alignment (see first photo), but the low beam aim is level/fine (second photo). So i am stumped why the drl is uneven if the lo beam appears to be level. I checked the high beam bulbs and they are seated properly. i haven't messed with adjusting anything because the low beam aim is fine and appears to be level. Car has not been in an accident and headlights appear to be okay and installed correctly. I have the AFS headlights and they work fine, adjust up/down and inward/out when first starting car and they turn on, and they adjust when turning on curves, etc..
Am i missing a step?
thanks
thanks
Returd
Performance & Maintenance
11-22-18 05:47 PM
