IS300 9006 to H3
I searched and came up empty. I recently picked up some '03+ SD fogs for my '02 IS. The 02 uses a 9006 bulb and the new fogs use an H3. Does anyone know of an adapter or wiring diagram for this conversion?
Thanks |
two options. Go to your local parts store and buy male 9006 plugs. PLug into stock wiring and then get you some spade both female and male to make a harness.
option two , cut the factory wiring, get spade connectors and then wire the h3.Pretty simple and straight forward. |
Thanks! I'll see what I can do
