Rx300 Parking Lights don't work
My Rx300 Parking Lights have never worked since I bought this car used 2 years ago. I installed aftermarket halos and hooked up the parking lights but still they do not illuminate. Any clues? Relay or fuse issue??? if so where is it located? Thanks!
There isn't much to say here without seeing the actual housing in person. All I can say is make sure all the plugs are properly plugged in on the housing.
You can check the fuse boxes. There are two. One under the engine and another under the dash, I forget which side (driver or passenger). I doubt there is a relay for it as it's a lower power bulb. Good luck! |
| All times are GMT -7. The time now is 11:35 PM. |
