HIDEXTRA.com HID Review
still having problem with my HID kit. This time it doesn't turn on and until I turn it on and off 10-20x. Then it finally fires up. It is wired to a relay harness. Only the right side does this. Anything I can do to fix this? The left side has no problems.
Hi Phiber,
What YR MAKE MODEl you have again ? and the bulb type and color you purchased? lexus don't need relays , you have to take that out to see.
And don't turn the light on and off too many times, otherwise you might blow the bulb, please let me know or call so our technician can diagnose the problem foryou. Thanks~
Michelle
Michelle
Hi Phiber,
Michelle
Michelle
Hi,
AH! take out the relay so it will work properly, if a car does not need relay, the relay will cause more problems. The ballast shouldn't be bad in this situation.
I have some scion customers who add relay when it's not needed and got the same situation and after they take the relay out, there is no problem. Keep me updated. THanks!
Michelle
Michelle
Due to increasing number of HID inquiries, please allow me 24-48 hrs to respond to your PM, thread replies or Email.
I will be overseas for the month of September but will still respond to all online inquiries. If you need immediate assistance or technical support, please call 860-821-8212 between 10am-4pm PST (Mon-Fri). Thank you very much!
HI,
Your bulb type is
2008 LEXUS IS F
Low beam headlamp
HID-D4S
High beam headlamp
9005
Fog/Driving light
H11
3000K will be bright yellow
here is the link to the H11 3000K ($60 shipped to US after coupon code: lexussp-w)
http://www.hidextra.com/HID+Bulbs/H1...28PAIR%29.html
Thanks!
Michelle
Your bulb type is
2008 LEXUS IS F
Low beam headlamp
HID-D4S
High beam headlamp
9005
Fog/Driving light
H11
Thanks!
Michelle
