s2000 projectors or TSX?
anyone have pictures or experience with either. TSX is what ive been recommended also what ive been researching.
what are your thoughts? |
Depends on the car. I only recommend S2000 if you have room to creat mounts in a bigger headlamp because of the projector's wierd dimentions and lack of screw holes. You have to get real crafty to get it to fit. If its your ES in the pic I would stick to TSX since both have similar performance but TSX is easier to install for most retrofitters and more practical between the 2
cool. what will i have to custom fabricate for the mounting? any ideas oh great one!
`R |
ALOT of cutting involved......emphasis on ALOT. Plus in your case because of how the inner lamp is designed by the way I remember it when I had the old ES, you probably can get it to fit with JB weld. Emphasis on probably but its a 50/50 shot because of the type of shape of the S2000 and the limited space you have to work with. I would stick with smaller projectors to be on the safe side. If you're gonna go large, I recommend reading Kyle Harty's thread. (Search Kyle Harty)
yeah i read through his and your troubles. i meant with the tsx projectors.
