Sponsored by: CARiD
need help on installing hid's !!!!!
Old May 13, 2005 | 07:43 PM
Neo's Avatar
Neo
The One
Originally Posted by lexusondubs
thanks neo so i need to order the 9006 male plugs for sure ?? oh and rom said he has the same comversion as me and he has the stock harness and has noo problems wierd ??
I will have to look at his car the next time I see him. The tech that installed the headlights for him had to do SOMETHING. The ballast has one plug while the car has another. Something had to give. I don't think he has the fuse/relay either but I guess in this case, it may not be needed since it is all OEM.
Old May 13, 2005 | 07:55 PM
lexusondubs's Avatar
lexusondubs
dubsonlexus
yea but seeing's how i already have the harness like $65 bux shipped should i try to return it?? but i dont understand it says plug and play no cutting of wires
Old May 13, 2005 | 08:11 PM
Neo's Avatar
Neo
The One
I had a theory about this in my post above. These harnesses are meant for HID kit retrofit. For example, if you had your original halogen headlights, you'd buy a 9006 HID kit. Your halogen headlights use a 9006 bulb and a 9006 connector plugs into it.
HID bulbs are not 9006. The ballast plugs into the D2S bulbs. Then, from the ballast comes another connector. I think the harness you bought is the link between the ballast connector and the 9006 plug of your car. The harness probably has a 9006 plug on one end and something else on the other. The 9006 end of the harness is actually the plug you need. Worst case, you can snip that off and use it but that would be a waste of a good harness while you can get the plug cheaper.
Old May 13, 2005 | 08:26 PM
lexusondubs
dubsonlexus
well on the zd website it says oem components ??
Old May 14, 2005 | 12:09 AM
mikal's Avatar
mikal
lexusondubs, keep the wiring harness.. It will prevent your stock wires from burning up sicne our stock halogen wasnt setup for HID.
So Here's a step by step. Hopefully you can undstand what i'm describing.
First of all, you already installed the XenonDepot Wiring harness i see.
Next is replacing the plug for the ballast.
Order some new Male plugs from suvlights.com. Those do not come with wires attached so you'll have to cut off the oem plug from ballast & crimp on the new pins provided to slide into the new 9006 male plug (if wires are too short, you can just extend the wires and solder in together.. be sure to use shrink wrap and wrap it back up with electrical tape for protection)
As for the Positive and negative, just use a power tester if you are unsure (I accidently popped a fuse when i reversed it) But as always, black wires are negative.
Sorry, no pix yet. I was too busy to snap some pix. And i'll be at my store full 11 hours shift this weekend. I'll try to snap pix on sunday.
Old May 14, 2005 | 12:38 AM
lexusondubs
dubsonlexus
hey man thanks for all the help ill order them right now the only thing iam confused about is when i cut off the plug from the ballast which 1 of those wires is positive and negative just dont want to risk blowing out the ballast i understand the work thing also i work a ton 2 i only have 1.5 days to complete this project (and i used up 1 today lol) before its work time again !!!
Old May 14, 2005 | 10:58 AM
mikal's Avatar
mikal
hopefully i'll have pix for you by the time your connector arrives.
Old May 14, 2005 | 01:31 PM
lexusondubs
dubsonlexus
lol ok
Old May 15, 2005 | 11:26 AM
rominl's Avatar
rominl
exclusive matchup
man this is getting so confusing. i guess i am the only one here on CL where i got the thing fit without cutting any wires?! thats very weird...
norcal gangs, let's get together and see how things are done. or maybe actually this will happen very soon @_@
Old May 16, 2005 | 08:39 PM
lexusondubs
dubsonlexus
i have the connectors do you have the pics ??
Old May 17, 2005 | 12:38 AM
mikal's Avatar
mikal
i'll take one in the afternoon for you.
Old May 17, 2005 | 01:10 PM
mikal's Avatar
mikal
k, here's the pix
Click to enlarge
Plug on left is the xenon depot wiring harness. Plug on right is the 9006 Plug that was purchased.
By looking at that angle, you can see where the pos and neg is suppose to be. While i was wiring mine up, i accidently switched it around. All that happend was it blew a fuse on my wiring harness. So if you're not for sure, grab some extra fuse.
Here's a picture of it semi-connected
Old May 17, 2005 | 02:39 PM
lexusondubs
dubsonlexus
sweet thanks man !!
Old May 28, 2005 | 11:23 PM
lexusondubs
dubsonlexus
ok i got everything hooked up and working but now how do i aim them ?? how will i know if they need to be adjusted ??
Old May 29, 2005 | 12:10 PM
mikal's Avatar
mikal
found this on CL when i was installing mine
File Type: pdf
