Sponsored by: CARiD
Replacing the 2nd light on the main Headlight
Old Aug 8, 2004 | 07:48 PM
MeehSoFly's Avatar
MeehSoFly
Default Replacing the 2nd light on the main Headlight
Guyz....I need your help!! I have a 92 sc400 and my second bulb on the main headlight is burn. How do I
replace that? Its the one when you arm and disarm the alarm it comes on. Is there a DIY on that? I tried the
search feature w/ no luck. Or Do i have to buy a new driver side headlight. Btw what size is that? If anyone
could help...I appreciate it.
Old Aug 8, 2004 | 07:55 PM
MeehSoFly's Avatar
MeehSoFly
Default Need Help on Replacing 2nd light on main Headlight
Old Aug 8, 2004 | 08:58 PM
AutoCoutureSC's Avatar
AutoCoutureSC
is it the tiny little bulb next to the main headlight? if so, just remove the bulb as you would the main bulb. just twist and remove.
Old Aug 8, 2004 | 09:05 PM
bizzy928's Avatar
bizzy928
I think its the 168 type bulb. Although mine doesn't flash when I unlock/lock the car.
Its tricky, you have to feel for it. Try searching the forums for a picture of the rear of the headlamp. It might give you an idea of what you are feeling for.
Old Aug 8, 2004 | 10:17 PM
G Star's Avatar
G Star
easiest way is to feel your way through the process, and let this word of advice help you (righty tighty, lefty loosey) if you want to, you can take out the battery and unbolt the airbox, get in there with a flash light.that should make things MORE CLEAR! good luck
Old Aug 9, 2004 | 12:55 AM
siaxazn's Avatar
siaxazn
If i were you i would just pull out the whole head light and it'll be obvious what you need to twist off to replace the bulb. Just unscrew the bolt on top and the 2 nuts that hold it in in the fender well, you can access the nuts easily by removing the fender lining a bit. The head light has 3 bulbs in it the corner bulb the main 9006 bulb and the little bulb and they all come out easily.
Old Aug 9, 2004 | 10:30 AM
siniquezu's Avatar
siniquezu
I'm not sure what you mean by second headlight bulb. There is only a low beam bulb (9006), a wedge bulb (194/168) and a dual filament turn signal bulb (1157 - if I remember correctly).
Old Aug 9, 2004 | 11:15 AM
G Star's Avatar
G Star
hes talking about the parking lights, i answered his question in the SC section. also there is a part diy tutorial of how to do it in the lighting section. check it out meehsofly.
siniquezu, you got pm
Old Aug 9, 2004 | 07:24 PM
MeehSoFly's Avatar
MeehSoFly
thankz guyz!! i'll try it this weekend. gotta do my 8-5 all week till this weekend. I heard there are pialights for
those parking light. where could i buy that?? except online....does autozone sell it??
Old Aug 9, 2004 | 07:27 PM
MeehSoFly's Avatar
MeehSoFly
Old Aug 9, 2004 | 07:39 PM
siaxazn's Avatar
siaxazn
yes
Old Aug 10, 2004 | 10:53 AM
siniquezu's Avatar
siniquezu
You can pick them up at your local rice shop. You could also get led ones. I just took mine out.
Old Aug 10, 2004 | 11:47 AM
G Star's Avatar
G Star
they're cheaper on ebay though, arent they? i been to the rice store at my mall called "auto mate(s)" i believe they were selling 194 white's for like 30 bucks a pop (not a pair).
Old Aug 10, 2004 | 07:38 PM
MeehSoFly's Avatar
MeehSoFly
I finally bought my 194 parking bulbs and put it in my headlights. It was a piece of cake if ya got thin hands...hehe. I decided to go with APC 194 Super White. They were pretty cheap...only 6.99 a pair, and they look decent too. Rather pay that than 20-30 dollars on some piaa parking lights.
Old Aug 10, 2004 | 07:40 PM
MeehSoFly's Avatar
MeehSoFly
BCT
Jun 29, 2018 08:53 AM
kodi2011
Dec 27, 2017 02:21 PM
rizzagt22
Jan 19, 2016 09:19 PM
omegabyte
Aug 28, 2012 06:04 AM
tryan24
Apr 21, 2006 02:35 PM
