Sponsored by: CARiD
Wedge Bulb in Low Beam Housing
Old Jun 13, 2004 | 06:16 PM
MrJohnE's Avatar
MrJohnE
Default Wedge Bulb in Low Beam Housing
Anyone got directions on changing the wedge bulb thats located in the low beam part of the head lights??? I Love my HID's but the yellow glare from the wedge bulb is annoying. How do i get it out??
Thanks - John
Old Jun 14, 2004 | 09:57 PM
lexusondubs's Avatar
lexusondubs
dubsonlexus
what lexus do you have ???
Old Jun 16, 2004 | 05:28 PM
MrJohnE's Avatar
MrJohnE
Default whoops
figured you'd see badxis30-0 hehe but yeah for an IS :
Old Jun 16, 2004 | 05:54 PM
rominl's Avatar
rominl
exclusive matchup
the wedge is just at the top of the housing, from behind the housing you can just twist it off?
Old Jun 16, 2004 | 08:34 PM
MrJohnE's Avatar
MrJohnE
Arrow u sure?
are you sure it twists off? i unhooked it and kept trying to turn it. it wouldnt budge. unless theres a trick? heheh anywho its an 04 Sport Design... ill give it another shot tommorow... maybe im just doing something wrong
Old Jun 16, 2004 | 11:25 PM
rominl's Avatar
rominl
exclusive matchup
it gotta be the same. i have the 03 and it twist right off though. forgot which direction but one way or the other it should come off
try the pessenger side firsrt, it has more space to play with
Old Jun 17, 2004 | 07:19 AM
MrJohnE's Avatar
MrJohnE
Default Thanks
Thank You Guys for the help. i finally got them out and changed. for some reason the sealing gaskets made it so tight to twist. i just used a pair of pliars. Once Again Thanks, - John
Old Jun 17, 2004 | 09:13 AM
rominl's Avatar
rominl
exclusive matchup
well at lesat that's a good sign it's not leaking
Old Jun 17, 2004 | 01:29 PM
MrJohnE's Avatar
MrJohnE
Question yeah!!
yeah! hehe anyway i have another ? to pose. The DRL/Highbeam Bulb 9005/HB3... the stock wattage is something like 65 W. i ordered a pair of Nokya Arctic Whites to replace this, however the guy sent me the Stage II bulbs which are higher in wattage... 120 to be exact... im thinking that because DRL is running at half power... the brightness of the Nokya Bulbs will be very bright as DRL's i believe. it makes sense. anyway i was wondering if anyone else is running this set up .
simplified - Bulb DRL/High Beam HB3/9005
High Beam DRL
Stock = 65W 33W
Nokya = 120W 60W
Thats what i think at least. That way i wouldnt have to upgrade the harness
Thanks - John
Old Jun 17, 2004 | 03:00 PM
rominl's Avatar
rominl
exclusive matchup
well, instead of checking out the DRL, try to imagine when you use the high beam, you will be doing 120w on the stock 65w wire -- terrible idea. i will not do anything to the high beam to get the DRL to look "good"
and also, keep in mind, that means you will be running 65w on the wires all the time (during the day). that's a lot of loading on the wires.
Old Jun 17, 2004 | 03:28 PM
MrJohnE's Avatar
MrJohnE
Question
is running the HID everytime u go somewhere a bad idea also?
Old Jun 17, 2004 | 03:34 PM
rominl's Avatar
rominl
exclusive matchup
some people might argue, but i have to say yes. that's wear that tear, everything has a time, so...
rkorduba
Jan 13, 2017 06:59 AM
Coolpop
May 17, 2010 08:49 AM
mepezzella
Feb 22, 2010 02:03 PM
MeTrO
Jul 13, 2006 08:43 PM
lex400sc
Feb 19, 2002 06:51 AM
