lighting FAQ -- READ THIS FIRST!
Old 08-08-07, 12:27 PM
SCpwner
SCpwner's Avatar
Default LED interior lights?
SC400/SC300 LED interior lights? Is there a certain kind and bulb number?
Old 01-08-08, 01:59 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,311 Likes on 1,410 Posts
Video from AACStyle demonstrating the correct way to disassemble and reassemble IS300 headlights. He says this actually applies to just about every Lexus and also shows the proper way to custom paint and install halos.
https://www.clublexus.com/forums/sho...d.php?t=328348
Old 09-09-08, 11:21 PM
LW ES300
LW ES300's Avatar
Exclamation Resource info - Philips lighting, All bulbs - 96 ES300
Here's some recent (8/21/08) info I got from Philips (all bulbs for 92-96 ES300). Hope it can help someone
http://www.philipsautolighting.com/r...b=ES300&c=1996
Old 11-10-08, 10:27 AM
98mkiv
98mkiv's Avatar
is300 front turn signal lamps, how do you replace the lower?
Old 01-19-09, 01:47 PM
isfcow
isfcow's Avatar
Can anyone show me how to change the bulbs on a IS 2gen ?
Old 05-03-09, 07:41 AM
trk1
trk1's Avatar
Default right hand fog lamp replacement
hi, im new here. i just bought a 1996 lexus es300 and i noticed the right side fog lamp is chiped and water has gotten inside and turned yellow. is there a replacement for the faceplate of the fog lamp?
also where on the light volume stick turns on the fog lights? i ask becaause i turned/pressed every button and the fog lights haven't turned on yet.
Old 05-03-09, 11:01 AM
GS4_Fiend
GS4_Fiend's Avatar
The fog light switch for the ES300 is on the same stick as the headlight. It's right next to the headlight turning switch. But on the right, you will see the tab. Just rotate it up.
Old 05-03-09, 07:31 PM
trk1
trk1's Avatar
Thanks, only the drivers side fog lamp turns on but the passenger side doesnt turn on. Im guessing this is because of the chiped lamp face and water getting in there.
Anyone have a DIY to fix the chipped face of the fog?
Old 11-11-09, 09:37 AM
Silverfeet
Silverfeet's Avatar
OK, hopefully somebody reads this: I have a 2006 GS 430 and had first the right front headlight (low beam)go out, and replaced it for crazy money. Lex folks told me that there was a computer associated with the light complex and that had to be replaced also. Is this true?
Also, the driver left side light (it is low beam also) is starting to fritz out. When I turn the lights off and back on again the low beam comes back.
Any help, any answers?
Thanks, all.
Old 11-11-09, 12:12 PM
emoshun
emoshun's Avatar
Thanks, all.
Welcome to CL! Sadly you've been taken for a ride from the stealership.
If the low beam goes out, you first want to attempt to replace the bulb, not the whole headlight. Even if the ballast (HID computer controller) was faulty they are very cheap on eBay and other sources.
Now that your other side is acting up, I would suggest you check out the bulb first, and then make a decision, because just letting the dealer do what it wants will hurt your pocket book quite severely.
-Jimmy
Old 02-28-10, 03:24 AM
Rom971625
Rom971625's Avatar
Couple of questions -
What type of HID do I use for my RX300 HID? I think I need D2R...which one? 4K, 6K, 8K?
Do i need to change both bulbs or just the one that burnt?
Any recommendations on the brand or mechant? god knows there are so many out there...
Thx for the Help!!!!
Old 06-04-10, 05:59 PM
USERNAME08
USERNAME08's Avatar
got a 2010 iS250. was wondering how to replace the fog light bulbs...thanks
Old 01-10-11, 11:48 AM
AJ92SC400
AJ92SC400's Avatar
Hey Lex Fam,
I have a 1992 SC400. The regular night time driving lights work however the the other set in front don't work. Maybe it's my error or something else. I checked the blubs which seemto be fine.
Help!
In the dark.
Old 02-13-11, 06:57 AM
ls400rgr
ls400rgr's Avatar
Default LS 400 Highbeams won't work????
Problem: LS 400 High beams won't work
Background: 1999 LS 400 with 270,000+ miles. Engine check light has been on constantly for 20K+ miles. Reading is for transmission error. Lexus has dropped, disassembled, and checked transmission and light error returns. Car shifts smoothly. Not going down that route again for $$$$$.
Current: Low beans work fine, will auto switch on as expected. Went to lexus parts, got replacement bulbs for high beams, removed old bulbs, the old bulbs looked fine. Added in new bulbs, they didn't work. Conclusion: the bulbs (old and new are ok) are not the problem.
Went to local mechanic. Said he is getting a "Hot" reading on both the hot and cold wiring leading in, but electrical is not his "thing". He charged me nothing (at least he was honest about his skill).
When switching the high beams on manually, the blue dash indicator light goes on, but no high beam. When pulling the tree stem backwards to "flash" the high beam, the dash light will go on, but no high beams.
Open to suggestions -
Thanks
Old 03-24-11, 02:35 PM
CitySlaka
CitySlaka's Avatar
I've got a 92 ls400 that uses 9004 bulbs and looking to convert to HID bulbs. I saw something about cutoff what's that. Also I saw the site HID nation and conversion is 40 bucks is that a good price.
Quick Reply: lighting FAQ -- READ THIS FIRST!
