ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Lighting (https://www.clublexus.com/forums/lighting-128/)
-   -   What's the difference: SS3 vs. Elite Series Fogs | Diode Dynamics (https://www.clublexus.com/forums/lighting/1011911-whats-the-difference-ss3-vs-elite-series-fogs-diode-dynamics.html)
Diode Dynamics Oct 12, 2023 09:10 AM
Today, we're addressing the comparison between the SS3 SAE-Fog LED Pods and our Elite Series Fog Lamps.
https://i.imgur.com/Fk7JLHx.png
The Elite Series Fog Lamp is built around a highly-engineered single-piece PMMA lens. This optic was carefully designed using advanced optical simulation software to produce a light pattern that is wider than any other aftermarket fog lamp on the market, with an 80-degree spread of highly intense light. Even with this extremely wide band of light, the pattern is extremely smooth throughout, with an extremely sharp cutoff to avoid glare to other drivers, including a BMW-style “color flicker” at the very edge of the pattern. Diode Dynamics engineers accomplished all this while still meeting SAE F3 fog light standards, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
https://i.imgur.com/xt756i0.jpg
The SS3 Fog Lamps feature higher output intensity than any other 3” light on the market, these LED pods have been designed for maximum functionality, with custom-engineered TIR optics shining in highly useful beam patterns, all in a durable package. With the included standard bezel, the SS3 Fog Kit has a clean, factory-style appearance, only much brighter.
Note: When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
https://i.imgur.com/03pn0MK.jpg
Elite Series Fog Lamps:
  • High-performance OEM-grade replacement
  • Custom-engineered optic provides extremely wide, intense light output
  • Distinctive integrated amber backlight
  • Road-legal fog light (SAE F3 compliant)
  • Plug and play main beam, no modification needed
  • Engineered and assembled in USA
https://i.imgur.com/LXHcvru.jpg
SS3 SAE-Fog LED Pods:
  • 3 Power Levels: Sport, Pro, Max
  • Advanced TIR optics provide high efficiency and focus
  • SAE-compliant road-legal output
  • Factory-Fitment, Off-Road Styling
  • Plug and play, no modification needed
  • Durable powdercoated aluminum extrusion
  • Engineered and Assembled in USA
Overall, our Elite Series fog lamps are right in line with our SS3 Sport regarding performance.
However, our Elite Series Fog Lamps utilize a custom-engineered patent-pending optic that delivers an extremely sharp cut-off, wide beam pattern, and unique BMW-style color banding.
If you're looking to crank up the output intensity, you can check out our SS3 Pro, but if you're seeking the highest intensity on the market with extreme width then the SS3 Max is the option for you!
If you have additional questions or concerns, please go ahead and give us a call at 314-205-3033 Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at contact@diodedynamics.com, and our in-house US service team would be happy to help you with that.
Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
Email: contact@diodedynamics.com
Phone: 314-205-3033
