The manual (p27) seems to say the electronic keys can be programmed so that the individual driver position memory is recognized by that key. I have tried to do this, but find only one positoin is recalled. That is, when I enter using my key, it does not reset to my position, unless I push the position 2 button on the door. Has anyone had success here?
I and others have had success with this. It does only adjust the settings when it unlocks the doors, so if you enter without unlocking the doors, it will not adjust the seat.
Do you have separate settings on each key, and the settings adjust for both without hitting the door buttons?
Yes. I'm #1, wife's #2. When I unlock with my key fob, it adjusts for #1. When she unlocks with the other key fob, it adjusts for #2.
One other poster did have the problem that if he and his wife both had their fobs with them, then the first to unlock the doors got the adjustment, even if they were on the passenger side.
If I remember right, to program the key fobs, I held the appropriate # on the door and the lock or unlock button on the key fob at the same time until there was a beep.
