- 2025 RX 500h - in-cabin air freshener on new vehicle??
- Questions about the ANCEL BM200 battery monitor, please
- 450+premium or 350h premium +
- VSPP on Lexus?
- Bang when slowing to a stop
- 2023 RX350H Jump Start Negative/Ground Connection Help
- RX500H Spark Plugs at 40,000 miles?
- Honestly, how's the Lexus App experience?
- My question for the 450h+ crowd….
- Plug in transformer
- RX 350h - Limp mode
- 2025 RX 450h+
- HUD green ghosting after Lumar Air 80% windshield tint – anyone else?
- 2025 350h AWD Tire Pressure
- RX 509h Black line discount?
- 2025 RX350h vibration
- Charging question RX450h+
- 2024 Rx 350h Any Software Update or bulletins
- Lexus 450h+ Actual ICE mileage
- Optimal Charging for Plug In Hybrids
- OEM Lexus Running Board RX450H+
- RX450H - Simple Quick Questions
- 500H Driver door opening while turning!
- Service campaign?
- High Mileage On Your 5th Gen Hybrid Yet?
- What happened to STOP CHARGING option?
- 2025 Rx 450h+ Question
- RX 450H+ EV versus HV odometer readings
- 2023 RX500h Owner Feedback
- Tips to maximize charging of hybrid battery while driving please.
- Lexus 12v battery issue - any satisfactory resolution?
- Lexus 2025 rx 500h black line edition windshield
- Tips and Tricks?
- New Lexus Owner - Questions
- 2024 RX350H AWD Door problem
- RX 450H+ redesign?
- 2025 Lexus RX450h+ Trailer Hitch
- Long road-trip experience with RX450H+
- RX 450h+ Window Sticker Fuel Economy 24 vs 25
- How long is is it taking to order/receive RX 350h?
- RX 450h+ Miles per kWh and EV Estimated Range
- 2025 rx500h mid
- 500H Paddle shifter or brakes on decline hill?
- 2024/25 - Premium or regular gas?
- Charging to 80%
- RX500h featured in WSJ safety tech video
- Long Term Storage
- Mark Levinsen amplifier location
- 450h+ Charging current -- 8A, 16A, Max?
- Wife mistakenly added diesel to RX500h
- Turn off "Next Charging Event" notification?
- RX350 vs. RX350h A/C
- RX500h sport rubbing noise
- DIY - differential and transfer case vents
- Lexus RX Hybrid vs PHEV: Which Is Better to Actually Own?
- Car Maintenance Tips
- Air Conditioning Compressor ICE or electric ?
- RX 500h F Sport Popping noise
- 500h turbo lag/bog when engine is cold
- Climate Control Fan Speed Jumps Forward
- Is the 450h+ 12v battery AGM or sealed lead acid?
- Did Lexus drop the Blue Logo for 2024 RX350H ?
- Engine feels rough when slowing down / driving slow
- 2024 RX 350h - Switch from S to D mode while driving?
- Up to what speed will the hybrid system run before engine kicks in?
- 2024 RX 500h Hitch Installation
- 24 RX350h Hybrid Battery Charge Level
- Defogger causing engine to activate
- Brake pedal feel in RX350h
- Level 2 charger for PHEV
- RX350H ride quality survey
- Power outlets remain active after locking doors?
- Does the rx350h have too many issues?
- RX450h+ need high test gas?
- PHEV/RX450H+ Fuel Health and Stabilizer use ?
- Get up and go on 2024 RX 350h
- 2023 RX350h Evaporative System Repair
- RX450h+ Off-road review
- Popping noise while A/C in on? RX 500H
- 450h+ doors open when charging complete
- 2015 450h to 350h
- RX350h Electrical System Block Diagram
- Active Noise Control/Cancellation
- Charge history not showing via app
- Does fuel economy change by switching drive modes in 450h+?
- Thinking about trading-in my '22 450h for a '24 450h+
- RX450h+ Insurance (in California)
- Towing Capacity Observation
- No spare on RX450+
- Is the RX 450h+ (PHEV) a better choice than the hybrid HEV?
- Daily Annoyances?
- Offset on aftermarket wheels for rx500h
- RX500h Top Grille Trim Replacement
- Dealer/car questions
- RX 500h turbo lag
- V6 GSR in the TX and not the RX450h?
- 450h+ or stay with hybrid
- 500h when start car
- Help with Warning on dashboard RX450+
- Extremely High Revving when foot is off gas in RX350H
- 2024 RX450h+ 12v Battery Load
- 25A-FXS Engine
- Hybrid Battey Level indicator
- Can you jump start hybrid battery?
- Hybrid Specs from Lexus UK
- F Sport accelerating on its own
- 1st Service - RX350h Lesson Learned!
- Toyota (Lexus) Hybrid TransAxle Explained
- RX350H 3500lb towing capacity
- Daily Operating Questions for RX 450h+
- Release brake pedal metal sound
- Engine reving like engine braking when deaccelerating
- How to make Drive mode and Map Settings to stick ?
- Is AWD always on in RX 350h hybrid?
- Rx500h F Sport brake failure
- Emergency release of gearbox of rx500?
- Oil filter and type for RX450h+
- Keeping the 12v battery in good health
- New Wheels for the RX 500h?
- Is 2024 RX 450h+ equipped with run flat tires?
- 2024 Lexus RX450h+ Handling
- Hybrid Batteries Replace
- 12v Battery Incident - Do not use Accessory Mode
- Computer controlled electric water pump are amazing
- Rx500 unable to start probably hybrid battery issue?
- RX450h+ Fuel Economy
- Clicking sound after start up - normal?
- Difference between the Turbo vs Hybrid engine?
- Moving backwards switching from brake to gas uphills
- RX350H Oil Change Interval
- 2024 RX 450h+ Initial Impressions
- RX350H HV Battery Cooling Intake Filter inspection?
- Brakes on the 2024 RX 350 Hybrid
- Do I have to drive somewhat pedestrian on the highways?
- Software Update Error 101
- General Hybrid Engine Behavior
- RX 500H Fsport poor accleration uphill
- 2024 Lexus RX450H Manuals
- RX350h Premium+ questions
- hybrid battery charging
- Why does RX450h+ use same battery as NX450h+?
- Feel vibration under feet?
- 350h downshifts (almost 4k RPM) when taking foot off Accelerator
- Engine Temp Reading 500h
- Sensor above the wheel on RX500h?
- CVT Transmission Behavior!
- Any way to tell hybrid battery charge level?
- Brand new RX500h went kaput
- RX350h with CEL P013A
- Rx 500H shudders when reversing
- RX500h or ..
- Coolant reservoirs on the left side of engine
- RX500h possible transmission issue
- How well does the AC function in the 2023 RX350h?
- Pennsylvania RX350h and RX500h Owners
- RX500h to RX350h Comments
- Is It Time to Give Up on My 350 Hybrid Order?
- 350h Tachometer Auto Switching
- AGC on RX350h?
- 12V battery charge mode
- ES300h to RX350h
- Rx500h owners - how many miles and any issues? Seeing a few recent posts with issues
- 500H- Occasional rev hang after initial startup
- Cargo space 2012 450h vs 2023 rx 350h
- Why is turning radius for 2023 RX500h less than RX350h?
- EV range RX450h+
- Oil Change DYI No Issues
- No EV mode in rx500h?
- Zero to Sixty in RX500h?
- 2023 RX350h Oil Change - DIY
- RXh A/C question
- Drove the RX500h for a week! POV Breakdown
- 2023 Lexus RX500h F Sport Exterior & Interior Walkaround
- Hybrid "EV" not always kicking in when it should.
- Rx350h 2023 engine noise when starting
- Hybrid malfunction
- Updates on the RX450h+?
- RX500H Ride Quality compared to a GLE450?
- RX500 Battery Voltage remarkably low
- RX500h Informative and Entertaining Video
- Are you ordering your RX 500h without a test drive?
- RX500H Premium or "super premium" gas?
- Activity Mount 2023 RXh
- Chimes on Start Up
- OBD2 Trouble Codes
- 2023 RX 350h Front Doors Not Soft Touch Close - Require A Little Extra Push?
- Width of 2023 RX350H?
- 500H Summer Tires sizes
- Towing with RX 350h
- RX 350H Driving modes, normal vs eco
- Distance to Empty - Not even close
- RX 350H has one of the highest dealer markups
- 2023 RX500h seat is like sitting on a steel bench
- 12V Battery Question
- RX 500h F Sport Hood Vibration at Speed?
- How to Turn Off Active Sound Control on RX 500h F Sport?
- RX500H Production - Hold
- My RX350h is dead in the shop
- RX 500h vibration in the brake pedal
- RX500h CEL, into the shop
- First Road Trip in new 350h
- RX 500H Jerky Transmission
- 4 cylinder with 6 speed 500h, or ecvt 350h
- 1st Lexus RX 500h in Scotland
- Octane for RX350h?
- RX350h Automatic Engine Start-Stop
- RX350h - MotorTrend Review "Too much vibration through the pedals"
- Does Regenerative Braking Reduce Brake Job Costs?
- 350H Hybrid All-electric Driving Distance
- Any RX500h owners can share their impressions/ownership experience of the car ?
- RX 350H in the snow
- RX350h Ownership Review
- RX350H driving in the mountains
- RX350h MPG
- RX500h MPG
- D Mode vs S Mode
- First look Rx 500h F sport
- 2022 Rx 450h vs 2023 Rx 350h
