- KW Variant 3 coilovers
- Brake Fluid Capacity for 2015 IS350 RWD?
- Best Coilover for Daily Drive / Comfort
- rotors & pad option
- 2020 3IS AWD Coilovers Question
- Brake pads - what do you guys use
- F-Sport RWD Suspension versus base model
- 15mm bolt on spacers
- Buying used Coilovers?
- Tein Flex Active vs RSR basic i-active coil overs
- RSR Half Downs measurements
- 3IS Coilovers List
- Wheel Spacers DIY?
- BC racing BR coil over install rear help!
- Dallas Spring Install Shop
- Rear alignment Parts needed for RSR downs
- 15mm Bolt-on spacers
- RS-R Down measurements
- rear bleeder valve
- RSR Half downs vs Factory F-Sport lowering Springs
- Bagged 3IS trunk set ups
- Bc racing br series coil install no adjustment out the box
- Okay lexus fam need serious help!!
- Tein S tech springs AWD
- 2017 IS200T Coilovers
- Going low. Need help.
- Camber Adjustment bar.
- Replacing stock calipers
- BC racing extreme lows
- Silvers coilovers
- Best Solution?
- Greddy KW vs RSR vs BC opinions?
- Bloxsport Spacers 15mm, not fitting
- Best Coilovers for Comfort
- Tires Recommendation
- Another suspension thread... 3IS needs a serious correction
- Install cost of lowering springs?
- Rear Shock OEM replacement costing me a leg and arm
- 19x9.5 +35 in rear on RSR Down?
- Shocks/Struts For IS 350
- is350 F sport AWD RSR questions
- Best bang for the $$ COILOVERS
- RCF/GSF Brembo Brakes on IS 200t FSport
- Yet Another Brake Post - 2018 IS350F RWD - what's the OEM+ option?
- Which rotors/brakes for 2017 IS 200t F-Sport?
- Which springs should I use to lower my 2017 IS
- Powestop z23 brakes
- Tein Flex Z Coilovers
- auto performance/tune shops in LA ??
- $1200 for coilovers & install?
- Handling In Snow
- Rear springs replacment
- squealing sound while driving under 20-30 mph
- OEM F sport wheel/tire set value?
- Better handles
- RSR half-downs on AWD?
- Comfort Suspension for 2017 AWD
- Air Suspension VS Partially Slammed Coilovers
- Is a camber kit needed for this set up
- IS350 coilovers
- 2014 Lexus IS250 AWD Wheel Spacers
- Putting RSR Superdown springs on my 50k mile Lexus
- Rotor Correction Plates
- RS R Downs Wheel spacers
- Replacing calipers Lexus IS300H
- Help with part #
- Rear shock replacement guide?
- Bad Brake Booster?
- 3rd Is250 F Sport Rear sway bar Part Number
- Lexus TRD lowering f sport springs
- Thinking about getting low.
- Need help on rim fitment for my 2015 IS250 F sport
- 2016 IS200t F Sport Brake Newbie ?
- Coilovers
- San Antonio Area Shops
- Shocks for RSR Down Springs
- H&R Trak Spacers rubbing on stock height
- 2018 is350 f sport bc coils
- In need of suspension torque spec for 2019 IS300 RWD
- Purchasing Brake Pads 2019 IS300 F Sport
- Sudden Vibration on a highway and rubbery smell
- 3rd gen IS 250 Brake Pad
- Looking for Suspension upgrade suggestions for my 2019 IS300 F Sport RWD
- Replaced struts 2 times in less than 50K miles
- Rsr coilover on 2017 is200t
- AWD springs or coilovers!?
- Tein Flex AVS Suspension
- Suspension noise after hitting deer
- Best coilovers for daily driving?
- Suspension help! New Lexus owner!
- Link to 2015 IS 250 Non F Sport Spacers
- 2017 IS350 Brake Squeal
- Best Pads for IS200T F-Sport
- Replacement Rotors
- Lexus IS350 AWD Base vs F-Sport Brakes?
- Type of Disc Clearance for Post Face IS (17+)
- Shocks For Lexus IS 350
- Wheel fitment
- 2015 is250 new rotor/pad rubbing issue help?
- Wheel fitment question
- Lower springs camber gain on is350awd
- Coilovers Option for new Lexus 3Is Owner
- Shocks & Struts recommendation 14 is350 f sport awd
- Noob question. Lowering 2015 is350 f sport series 2
- RRRacing Penske coil overs
- 18x8.5+41 front 18x8.5+37
- How wide wheels can i go with rsr superdowns
- Lowering Springs For IS350
- RS*R Down - Spacer question
- Calling All Canadians - Brake Pads - Akebono?
- Polyurethane sway bar bushings
- I-shock Active PV
- I need new front brakes & rotors
- 2014 IS350 brake bleeder screw
- Rotors? and Pads? OEM Mark Textar vs Aftermarket for IS350FSport
- Front strut replacement - only one or two?
- Wheel Spacer help is200t fsport
- Noob question
- Suspension upgrades
- 2018 IS300 FSport
- Figs bushings installation
- Gs350 shocks/springs fit is350?
- Scraping on rsr downs???
- Need help with front shocks!
- Torque specs for caliper bolts and caliper bracket bolts 2015 IS350 F sport
- Best Rotors??
- DIY quick alignment using eyeballs and a wrench
- Rear After Market Shocks For Air Ride
- 2016 is200t f sport brake service
- Aftermarket Shocks
- Looking for lowest drop possible without rubbing on 3is
- Stock height w/ Seibon Kit
- RSR down installation cost
- 2is suspension compatibility?
- Lowering IS250/ RS-R or alternative
- Lowering springs
- Recommendations
- IS350 front brake noise when turning
- RSR Down squeaking noise
- IS200T Front left wheel bearing
- Quick groan when I step on the brakes downhill
- GSF/RCF Bushing Offset
- Change Rotors
- 10J +40 vs 10J +45
- Akebono Brake Pads 2017 IS F sport
- 18K/20K BC issue.. With pictures
- R1 Concept Rotor/Pad or OEM/Akebono Pads
- Front rotor confusion
- Possible Rear Swaybar Upgrade Alternative - 16'-18' Lexus RC?
- Rsr Ti-2000 Downs
- Sway Bars
- RS-R downs F-sport vs. non F-sport?
- Weird brake pedal feeling
- 2016 IS 350 F sport springs with 19” wheels?
- Recommendations on rotors and brake pads for a 3rd gen is350f
- 14 is350 awd scalloped right rear tire after 14k!?!?!?
- IS350 - RCF bushes installed today
- What colour calipars HELP
- Are there AVS compatible coilovers?
- STB options???
- RCF/GSF bushings
- 2018 IS300 - Car Pulls Right
- SWIFT Springs worth it?
- Fsport lowering springs for 2016 is350
- Lexus brake pad & rotor part number?
- RR Racing LCA Bushing
- Air ride question.
- Lexus Is250
- New Rotors & Pads Recommendation
- 2014 IS350 AWD FSport with RSR Downs feels rough
- RS-R down or ARK Performance
- Abs sensor malfunction after Timken hubs installed.
- Vossen 20" Need help on fitting
- rear brakes diy?
- Brakes problem Lexus IS300H 2014
- 2015 IS250 F Sport AWD Braks and Rotors
- Don't get your alignment until you read this! Hunter Specs are off.
- Suspension Issues
- IS350 OEM Pads and Rotors
- New to coilovers. help?
- 20x9 +20
- RSR Downs... are they gonna work?????
- SBC rear camber arms for 2018 IS
- Tire Buying Whoas for 19x10
- Suspension differences
- 5mm pads after 7100 miles; replacement protocol?
- Brake Fluid Tester reading 3% Moisture
- Post your Lowered Alignment Spec Printout
- OEM GS-F LCA (Caster) Bushings and Lowered Alignment
- F-Sport OEM Lowering Spring
- rear shock blown
- 2015 IS350 F-Sport - Looking to get Air Lift
- Help!! Spacer Wobble!!
- 2015 IS 250 AWD Non F Sport strut / sway bars?
- Advice needed on SPACERS
- Suspension Noise.... I Think !
- Upgraded brakes necessary?
- T-Demand video may explain 3IS extreme toe wear problem ..
- Should I change my rotors
- BC coilovers installed with 20mm spacers all around
- RSR sport I coilover owners
- 2017 lexus IS 200T f sport Brakes
- RSR Downs and Stock Shocks
- Coilover options - 2015 IS 350 F AWD
- RSR Down Lowering Springs
- Low Springs to Higher Springs
- Rear Shock Absorber Help
- rsr down springs and rr racing lower control arms (usrs)
- IS350 AWD RSR Install Estimate $700
- life span of OEM rotor and brake pad
- Help: 3IS 350 fsport awd rotor fitment issue
- 2017 IS 300 Squeaking Brakes
- Akebono Pads - Proact vs. Performance
- Rear coilover help!!
- Coilovers help!
- Airlift rear bellow bags
- F sport springs and shocks
- Wheel size/offset question
- 19x10 vs 19x10.5
- Front Brakes & Rotors after 12k Miles
- caliper rebuild help
- RSR Down springs
- 2014 IS350 Rotors & Brake Pads
- Lowering Springs IS350 2014 Fsport AWD recomendation
- Caster alignment
- 2015 is250 F Sport Lower Front Lower Control Arm
- New Suspension set for Lexus is200t
- Fitting Kit and Shim Kit Needed?
- Recommended Rotor Brands + Brake Pads
- REAR Brake Upgrade Options for AWD F-Sport?
- WHeel size and tires
- Tein S tech and RSR Down
- Brake upgrade recommendations 2014 is350 fsport AWD
- Brake painting and decal
- Finally lowered and Summer shoes on!
- RCF/GSF OEM BBK on 3IS
- Clunk Suspension after 40k
- Picked up a 2018 IS300, can't find suspension
- Question about RS-R Downs
- Importance of sway bar links
- BC Coilovers clunk / thump in rear
- Air ride controller mount
- Lexus Is250 awd coilover?
- Lowering Questions
- 2017 Suspension - Show 'n Tell
- Driving Freeway Speeds Cant Go Straight
- Knocking noise when lowered?
- Remote start
- Lowering Springs IS200T
- upgrade brakes
