image dynamics or w7's
hi I need some help deciding on upgrading my 3 12 inch subs I have them installed in a custom sealed enclosure I would like opinions on which sub would be better for me jl audio 12w7 or image Dynamics ID MAX 12 v.3 D2 I plan on running 3 Rockford fosgate power 1500bd amps one for each sub thank you for your help
Sealed, W7 will have more output and IMO a little less quality then a MAX. Not by much though.
you think i would get more spl with the jl w7 then
1 Attachment(s)
i also found these Rockford Fosgate TRF2212 dual 1.4 ohm VC!
2000 watts RMS 4000 watts MAX! 75lbs! |
thanks retrodrive
do you know the best place online to buy w7's or idmax v.3 |
I love my 10W7. Just spectacular. I"m using a JL 500/1 to drive it.
how good does the bass sound from your 10w7
Originally posted by kidcapp i also found these Rockford Fosgate TRF2212 dual 1.4 ohm VC! 2000 watts RMS 4000 watts MAX! 75lbs! |
thanks LS400
I have WAY more bass than I need. Very deep and full, very clean and the box is tiny. I have it firing through the factory hole and sealed against the rear deck. If you want obscene bass you can always go for their 13 incher and use their 1000/1 amp to drive it. Can't imagine why you'd ever need more bass than that.
i am thinking of using a 3 or 4 12w7subs and using two rockford fosgate 1500bd amps
Sounddomain.com is one of the only official IDMAX dealers. If you find a cheaper price anywhere, they can pricematch it. If you want so much bas I suggest 2 x 13W7 in well tuned ported enclosures. That would be enough to not being able sitting in your car at half volume. Make sure your electrical system can hang.
thanks retrodrive where can i get w7's online at good prices so you think 2 13w7 are better then 3 or 4 12w7 how about if i use 3 13w7
does anyone know where to get w7 at a good price thank you to every that has helped me out
Go to Tweeter and negotiate with them. They are really flexible on pricing these days.
| All times are GMT -7. The time now is 08:58 PM. |
