Stock radio question
Old Dec 11, 2002 | 09:45 AM
LexRoc's Avatar
LexRoc
Default Stock radio question
I have a very minor problem with the stock unit in the car.
When I have a CD in, the display that shows what track its on is partially missing. Example: if its on track 12, the top part of the 2 is missing.
Im just wondering if this could possibly be the start of problems with the stock unit. The car is still under warranty, so if its a sign of things to come, i'll bring it in. If its no big deal, I'll just leave well enough alone.
Thanks for your feedback.
Old Dec 11, 2002 | 09:59 AM
BananaGS's Avatar
BananaGS
Tech Guru
this topic has been discussed many times, try the search next time.
just take the car in, lexus will replace the radio for free when you are still under the factory warranty.
Old Dec 11, 2002 | 02:20 PM
LexRoc's Avatar
LexRoc
Thanks for your reply, but what would you suggest I put in the search engine??
Im still interested to hear from others who experienced the same thing, and if it was the start of many other problems.
I know this isnt a big deal, just curious for the most part.
Old Dec 11, 2002 | 02:56 PM
RX300TC's Avatar
RX300TC
Roc,
This is nothing more than a display problem. It happens in all kinds of appliances that use LCD or LED type displays.... could be a bad display element, PCB connection, faulty jumper wire, etc.
As previously stated, take the car in and they will replace the unit. What does it matter if it is leading up to something....they are replacing the entire unit.
Good Luck.
Old Dec 11, 2002 | 03:41 PM
BananaGS's Avatar
BananaGS
Tech Guru
try to search using some of the key words in your post
I tried "radio missing" there are at least 15 other posts come up on this subject. Lexus replaces the whole unit, period.
not being a ***** or anything, but there are lot if info buried in this site, almost everything
Old Dec 14, 2002 | 03:09 PM
LexRoc's Avatar
LexRoc
Hey fellas,
Thanks for the replies Much appreciated.
hcstraub
May 4, 2014 03:22 PM
McKrevice
Jun 27, 2009 10:35 AM
rudeboi
Apr 17, 2005 06:18 PM
(f)-LEX-ible
Dec 21, 2001 11:55 AM
