ohm question
I have a 2 ohm 350rms watt amp and a 400rms watt 4 ohm subwoofer.
Should i wire the sub to run 2 ohm? i want to get the most power out of my application. |
Originally Posted by maxx430
(Post 7467507)
(Post 7467507)
Big Mack |
Thanks for comment Mack. I have a mono amp mrp350 and a CVR 10 kicker(the silver one).
(Post 7467792)
Amp is stable to 2 ohms, so if it's dual 2, you would not be able to load it to that. If it's dual 4, just wire the coils in parallel (both + to the + on the amp, etc.). Big Mack |
The back of the sub said its 4 ohms.
So i guess i can connect both + to + and - to -. I then run wires from the amp to either one of th sub terminal? Does this make louder? man am i such a newbie |
(Post 7468203)
(Post 7468203)
Big Mack |
(Post 7468203)
