Radio Problems
Old Nov 21, 2002 | 01:18 PM
oceanguy's Avatar
oceanguy
Default Radio Problems
I am having problems with the sound system on my 1990 LS400. Last night it was working fine and then there was a crackling sound and now nothing works (no radio, no CD, no tape.) I checked the two fuses associated the radio (under the hood and under the dash) and they appear fine. The panel lights work fine, but no symbols. The volume/on off dial still operates the antenna. Any suggestions?
Old Nov 21, 2002 | 01:35 PM
chliansh's Avatar
chliansh
Is your trunk wet? When the trunk weather seal fails its seems to dump water around the changer in your trunk.
Old Nov 21, 2002 | 08:05 PM
meZoom!'s Avatar
meZoom!
Super Moderator
I'm not a radio expert but because you heard crackling, i am thinking failed wires/connection (????) from the head unit. lets try your luck in the electronics forum.
Old Nov 22, 2002 | 02:10 AM
Cleeve's Avatar
Cleeve
Default Sound Problem
oceanguy,
I think you need to give a little more info. Does the radio turn on and does the display show any numbers on it? If yes to that then the amplifier located under the CD changer may very well have gone bad. What is the number on the cass door so I can identify the system you have? I will be waiting for the info. You may contact me at my Web site: www.lajollaaudiorepair.com
Cleeve Morrison
La Jolla Audio Repair
cody09
Jun 5, 2013 11:03 PM
MrBrock
May 26, 2012 09:03 AM
91LS4004RM
Mar 18, 2009 09:50 PM
