Adding amp/sub to stock system
Old Apr 13, 2010 | 10:54 PM
QuachmanES's Avatar
QuachmanES
CL Folding 25,000
Default Adding amp/sub to stock system
I'm looking to add an amp and a sub to my stock system in my 99 ES300. What I'm wondering is if I need to use a line output converter to connect to the stock speakers or if I can just connect the loc to the stock sub output?
Any solutions?
I will be using a 500W Alpine amp and a 10" Alpine Type-R. Any help is much appreciated.
Old Apr 14, 2010 | 08:43 AM
Lust4Lexus's Avatar
Lust4Lexus
I think you can use the LOC and tap it off the output in the trunk. after all its the same signal from of the amp vs/at the speaker terminals. whey create more work?
Old Apr 15, 2010 | 06:05 PM
QuachmanES's Avatar
QuachmanES
CL Folding 25,000
So I just picked up the stuff today and tried to hook it up, but I could not find a way to get the power wire for the amp through the firewall to connect to the battery.
Any help?
I couldn't find a hole in the firewall or the engine bay to snake the power wire through.
Old May 13, 2010 | 05:02 AM
mr3gs300's Avatar
mr3gs300
try around the rubber boot of the steering columm then once u run the wire thru u can use silicone to seal the hole around the power cable then just either run it thru the side of the doors sills or if u really wanna do it right run it thru the middle of the car under the rug to the trunk
eurodre
Nov 27, 2020 08:18 AM
crwys
May 31, 2014 04:19 PM
vicious
Jun 28, 2011 08:39 PM
ls_lextasy
Sep 2, 2009 05:34 PM
sc4009688
Dec 12, 2005 05:33 PM
