Vais "I agree" problem
The "I Agree" doesn't just go away by itself. You have to program it from the Nav screen. VaisTech has instructions on how to do that. Unfortunately, they are incomplete. I finally called VaisTech and talked to support. It was even difficult talking to them.
Basically what you are to do is to activate the Simple Mode screen, change the deactivate setting, and then close out the Simple Mode screen. They don't tell you how to get out of the Simple Mode screen. Without proper exiting, the change fails.
Here's the step-by-step procedure to do this:
1. Activate the Simple Mode screen by opening the MD Changer screen and pressing SCANN button (on the screen) 8 times within 2 seconds.
2. Press the DISC REPEAT button to hear the long beep.
3. Now comes the part they didn't put in their instructions. You must get out of the Simple Mode. It is done just like getting into the Simple Mode. Press the SCANN button 8 times within 2 seconds. Apparently the VaisTech technicians assumed that everyone would understand that and it wasn't necessary to include in their instructions.
Be aware that the "I Agree" screen doesn't really go away. They have programmed the SL2Vi to press the button for you after it displays for an adequate time to read it. That short wait is worth it and you quickly learn to ignore the screen during start-up
Thanks for the quick reply! Did what you said and works perfect. Thank you very much!
Check out this post on the LS430 forum https://www.clublexus.com/forums/ls4...ag-screen.html for steps to bypass the "I Agree" screen.
dseag2
May 2, 2025 11:29 AM
NXOwner
NX - 1st Gen (2015-2021)
Oct 2, 2015 08:57 PM
