Last edit by: IB Advertising
Browse all: Interior
- How do I Install Aftermarket Amplifier power wire
Step by step instructions for do-it-yourself repairs
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
#122
Hi,
first off great write up definatly played a big role when i was installing aftermarket subs and they work great. but there was one thing im just not too sure of, i know i can definatly make my subs work but what about my oem speakers? i got a harness off ebay and it fits where socket A is and the little blue harness.basically will my oem speakers work without doing this?
thanks
thanks
#123
Hi,
thanks
thanks
#124
Guys,
Maybe someone can help me here. For some reason my stock radio isn't turning on. This is what I have tried.
Switched out radio to a different radio
Switched out climate/volume control plug
Checked 20a fuse under hood
Checked 7.5a fuse in kick panel
I didn't have access to this thread last night to check the schematics. I did notice I was getting 12v from a blue/yellow wire - but don't remember from which plug.
The climate control is working, just not stereo. By not working, I mean not even turning on. All plugs were securely connected.
Anyone give me some ideas on where to start or which wires to start checking? It is a 92 SC with Pioneer stereo.
Thanks,
Jonny
Thanks,
Jonny
#125
Guys,
Thanks,
Jonny
Thanks,
Jonny
#128
i connected A1 and A8 to the aftermarket antenna wire and my the radio turns off and on when i put the source on tuner. but everything else works fine, so i disconnect the antenna wire and the radio works fine and doesnt turn off.
#129
I used this tutorial for switching out my Nakamichi system and for the most part everything is the same. The only part that I found any different is wiring up the antenna to work only when the radio is on. Instead it goes up when the stereo is turned on and will only go down when the car is turned off. I'll figure it out eventuall I just ran out of time. I don't know the differnces between the two systems but all the color coding is the same
#130
thankz for the write up raine i found a lot of useful info but i do have one question im not sure who said it but i wanted to use the stock volume **** as a remote for my subz how would i go about doing this i know it might sound like a stupid question b.c you guyz seem to really know your **** but if you could just explain it and throw in a pic or two that be great thankz again
#131
#132
so you cant just splice into it and run a remote wire to the amp cuz i have a remote **** that plugz into the amp but i waz wondering if i could just slice into that volume **** and use it as the **** for the remote you kno?
