Is this a good replacement sub??
I just got a free mtx audio mzs1004 and I was wondering if it is a good replacement for the stock ml sub?? And would I need an aftermarket amp to power it up?
Here are the specs
MPN MZS1004
Key Features
Car Speaker Type Component
Elements 1-Way
Car Speaker Function Subwoofer
Size 10"
Nominal Power Handling 300 Watt RMS
Powered Non-Powered
Technical Features
Frequency Response 35 Hz - 150 Hz
Sensitivity 88.3 dB
Impedance 4 ohm (Dual Coil)
Components
Woofer Material Metal
Surround Material Rubber
Mounting
Enclosure Non-Enclosed
Top Mounting Depth 6.16 In.
thanks in advance.
Here are the specs
MPN MZS1004
Key Features
Elements 1-Way
Size 10"
Powered Non-Powered
Technical Features
Sensitivity 88.3 dB
Components
Mounting
thanks in advance.
mpsarmi
09-08-07 11:32 PM
