pollyfil?
Old Dec 12, 2007 | 09:23 PM
alexulan's Avatar
alexulan
Default pollyfil?
I have to replace my sub and have the box open.
What is pollyfil? or more importantly what can i substitute in there?
Right now the inside of the enclosure is bare.
I don't thin I want anything loose in there
because the box has a radiator type design.
I'm thinking gust stick some dynomat type stuff to the inside walls?
Old Dec 13, 2007 | 02:13 AM
Havok13154's Avatar
Havok13154
polyfil makes the box seem bigger tricking it and giving it the sound of a bigger box.
DO NOT PUT DYNOMAT INSIDE OF THE BOX
Old Dec 13, 2007 | 06:33 AM
AZ IS350's Avatar
AZ IS350
Polyfill is basically the stuff inside your pillows, stuffed animals, etc. You can buy it loose from fabric stores or maybe in the fabric section at SprawlMart but if you wanna go cheap just rip open an old pillow.
Old Dec 13, 2007 | 01:59 PM
alexulan's Avatar
alexulan
I guess I'll try it.
Worst case senario I can always pull it out.
Sound like the formula is 1/2lbs per 1 cubic foot. loose
Acousta-Stuf is a synthetic material made from crimped fibers. It is an excellent choice for filling small enclosures or transmission line cabinets. Long fiber wool has been a favorite among serious speaker builders but Acousta-stuf is less expensive than long fiber wool and does not have the problem of harboring moths. Acousta Stuf™ will also outperform Dacron, foam, and fiberglass. Acousta-Stuf is a sound absorption, dampening fiber that will deepen bass, provide cleaner midrange and improve the dynamic extension of any speaker system. There are no health hazards with Acousta-Stuf and no mask or gloves are needed when using this product. Most sealed and vented enclosures require 1/2 lb. of dampening material per cubic foot of enclosure. For best results it is recommended to loosely fill the material throughout the enclosure.
Old Dec 14, 2007 | 11:11 AM
5sp_jzz30's Avatar
5sp_jzz30
polyfil is used inside sub boxes to make them "seem" larger in volume. the polyfil will slow down the speed of air and since the air is moving back to the sub slower it seems that the enclosure is larger. you ratio for polyfil per ft is about right. good luck.
brociouz
Apr 25, 2019 08:58 AM
SoarDaSC
Feb 27, 2012 09:14 AM
biglexass
13
Aug 13, 2006 07:00 PM
bumfighter
Apr 10, 2006 06:50 PM
DJ SprinklesNJO
22
Jun 18, 2002 08:32 PM
