alarm door trigger
Old Jun 22, 2007 | 07:31 PM
vstyle444's Avatar
vstyle444
Default alarm door trigger
where can i find the door trigger wire on 01 gs300 Door Trigger Body Module Driver's Kick 25 Pin Connector #13 Delay Dome Light ?....also the tach wire say blk/yel Module under Hood Driver's Side 28 Pin Connector Pin16 i found the conn buts a different color
im sure someone out there did this before that can help me
Old Jun 23, 2007 | 12:57 AM
vstyle444's Avatar
vstyle444
anyone my car is apart
Old Jun 23, 2007 | 05:40 AM
dentpusher's Avatar
dentpusher
This should cover everything.
12volts white/blue + ignition harness
Starter black + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition black/white + ignition harness
Third Ignition
Accessory blue/yellow + ignition harness
Second Accessory
Keysense yellow - ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the alarm without unlocking the doors.
Power Lock see DirectFax document 1070
Power Unlock
Lock Motor green/red + drivers door module
Notes: The drivers door module is located in the drivers door.
Unlock Motor green/black + drivers door module
Parking Lights+ green bottom right of fuse panel
Parking Lights- red/yellow under steering column
Door Trigger green -
Notes: To beat the dome light delay, go to each door module located in each door. The wires are : red/white for drivers door, red/green for front right door, red/white for left rear door, and red/yellow for right rear door.
Dome light supervision wire is located in a 25 pin plug pin #13 behind the fuse panel in the passenger kick at the body ECU.
Dome Supervision green -
Notes: Dome light supervision wire is located in a 25 pin plug pin #13 behind the fuse panel in the passenger kick at the body ECU.
Trunk/Hatch Pin red/white - drivers kick in 20 pin plug
Hood Pin violet/green - pass kick in 25 pin plug
Trunk/Hatch Release vio/yel or blue -/+
Notes: Violet/yellow(-) is at the switch or the blue(+) at the drivers kick in a 18 pin plug.
Fuel door lid is a blue/white(+) at the switch or at a 20 pin plug, pin #16 in the drivers kick.
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black/yellow 28 pin plug, pin #16
Notes: Located inside ECU box which is under hood on the drivers side.
Wait to start
Brake Wire green/white + drivers kick in 20 pin plug
Parking Brake
Horn Trigger green/black - steering column
Immobilizer Bypass Required:
Yes Type:Transponder
Part #: 1100X
Alternate Part1 #: 1100F
Alternate Part2 #: 555XW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: The synch wire is blue/red, clock wire is black/white, data wire is green/black, ignition wire is black/red, and ground wire is white/black. When using the 1100F, a software change to 1100TL is needed.
Old Jun 23, 2007 | 12:44 PM
vstyle444's Avatar
vstyle444
thankz for the help i found the 28 conn for the tach wire but the 16pin its not blk/yel
Old Jun 23, 2007 | 05:50 PM
vstyle444's Avatar
vstyle444
can anyone help me on the tach wire im stuck on
Old Jun 24, 2007 | 09:01 AM
vstyle444's Avatar
vstyle444
anyone has a pic where you hook up the tach wire thankz
Found it
Old Aug 30, 2013 | 07:44 AM
damiendada's Avatar
damiendada
I know this thread is old but I had this problem and I got mine fixed so I will share for others. Tach wire comes from Coil pack controller under the hood. or what ever its called. its on the driver side above the shock tower. black/yellow wire labeled TAC.
Jjrx330
Jul 25, 2017 12:08 PM
tunanaut
Jun 25, 2015 04:07 AM
d1trainee
Sep 8, 2010 10:39 AM
python
Mar 16, 2009 08:50 AM
tritron
Apr 16, 2007 06:41 PM
