ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Lexus Audio, Video, Security & Electronics (https://www.clublexus.com/forums/lexus-audio-video-security-and-electronics-12/)
-   -   so here's the deal... (https://www.clublexus.com/forums/lexus-audio-video-security-and-electronics/261300-so-heres-the-deal.html)
Aristo94 Jan 26, 2007 11:06 AM
I hooked up a dvd player to my 1994gs300 and got everything but subs hooked up. so I have all the wires ran for the sub, (power, ground, rca and remote) and well, when I get it all connected and try to get the amp to power up i get nothing...could this be a bad ground?? :dunno:
olddog Jan 26, 2007 12:45 PM
yes, it could be bad ground.
it could also be fried amp. where did you get it from?
it could also be power cable. did you put in the fuse?(lots of people forget to put the fuse in after installation)
check all your connections and make sure they are all hooked up nice and tight.good luck
Aristo94 Jan 26, 2007 05:31 PM
i tried another amp and it still didnt work and yes i put the fuse in and well i think its the fuse setup that i have im just gonna try the glass fuse instead of the wierd lookin one that i got...if that doesnt work then il just re-run all the wires and be sure everything is connected
GSoup Jan 27, 2007 02:28 AM
do you have a current tester?
something like this...http://www.fab-corp.com/prodimages/freemeter.jpg
that would be the easiest way to trouble shoot the problem and figure out where the current stops.
350g Jan 27, 2007 09:57 AM
Odds are, either your remote or power wire is not hooked up right . . . get the multimeter like Gsoup suggested and find out which wire doesn't have power and research it from there. I'm guessing its the remote wire . . . may not be triggering the amp to turn on due to a variety of issues. Do you have the remote wire attached to a relay (useful to make sure that you don't burn up the lead)?
Aristo94 Jan 28, 2007 04:50 PM
even if the remote wire wasnt hooked up the amp would still turn on as long as it got power and im not even getting that so its not the remote i have that one down im just gonna get the new fuse set up this ones newer tech and im gonna stick to the old stuff i know that works...but il try that n get back...thanks tho everyone!
engin_ear Jan 28, 2007 05:47 PM
Incorrect.
88supramki Jan 28, 2007 06:01 PM
Just as Enginear said, that is incorrect. Only if you made a jumper from the power wire into the remote turnon with it actually turn on without a signal from the headunit. The reason for the turnon is so that your amp doesn't drain your battery from being on all the time, only on when your headunit is on because your amp is directly connected to your battery.
350g Jan 29, 2007 07:07 AM
And for the record, we don't recommend using the "jumper" setup, but it could be an easy way to rule out your power wire. I'm just curious though, why don't you just shell out a few bucks and have it all professionally installed?
Aristo94 Jan 30, 2007 11:45 PM
haha cause im only 19 and dont have job....my parents bought me the car:p plus im all for learning how to stuff plus it'l save my parents from givin me money to get something done that I've already done 90% of. I installed my dvd player/deck which works fine im just having probs with my subs, but il figure it out once I get some time to get back out n work on it! plus its cold and the weather is iffy these days in oklahoma :sad:
