JL Cleansweep and Alpine H701?
I was going to get an H701 to process the sound in my car. I have a iS250 with nav and would like to keep the stock HU. Would I still need to buy a cleansweep to get the cleanest signal possible? As I would still like to retain nav commands and such.
My plan was to eventually get a VAIStech video unit (when they come out, supposedly sometime at the end of the year) and then have everything to the H701.
Or the other alternative was to just scrap the OEM changer and put in a Alpine W200 and hook that up to the h701.
Thoughts?
Thoughts?
Everything in Moderation
You can also think about the Alpine PXE-H650.
If you're not going crazy you can use JL Cleansweep or 3sixty.1.
If 6-channel, etc, then 3.sixty.2.
I don't exactly see how the Rockford 3sixty is more advanced than the Cleansweep - they're both digital correction EQs, but I haven't used them.
check out the specs on the 3sixty.2, you have individual 32 band eq's for each speaker, as well as time alignment, and MANY more options. You do all of the editing through a bluetooth enabled PDA, which saves your info on to it. if your system crashes, resets, or whatever you just load in your profile and BOOM....back to the way it was as if nothing has every changed.
sorry, not 32 band for each speaker. here's the quick list from the features section
6-channel high-level input
6-channel RCA level inputs (FR/FL/RR/RL/Center/Sub)
Independent 31-band EQ for Front Left and Front Right
Independent 27-band EQ for Rear Left and Rear Right
27-band EQ for Center
10-band subwoofer equalizer
6-channel HP/LP/BP/AP adjustable crossover
Up to 5 feet of delay per channel in 2 inch increments
Auxiliary RCA input with 31-band adjustable eq
Auto equalization with auto sum capability
Digital Signal Processor with OEM integration capabilities (patent pending)
Remote programmable master volume/aux volume control
Wireless Bluetooth®
Wireless Bluetooth®
unless you REALLY know your car audio, then you should have a certified dealer install it for you. and the ones who sell the 3sixty.2 should have a PDA ready to do all that.
we have all of our 3sixty.2 customer's profiles saved in our pda so that we can load them back in if there's ever an issue.
Doneve79
14
10-16-10 02:04 PM
OC 335d
08-29-10 06:32 AM
GSJDM430
04-28-09 11:59 PM
westcoast
11-07-06 09:45 AM
