ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Lexus Audio, Video, Security & Electronics (https://www.clublexus.com/forums/lexus-audio-video-security-and-electronics-12/)
-   -   GS4's with Capacitors? (https://www.clublexus.com/forums/lexus-audio-video-security-and-electronics/233251-gs4s-with-capacitors.html)
Kharizma Aug 16, 2006 06:16 PM
what kind do you use? and are you able to tell the difference? i'm thinking about getting one and don't know if i need 1/2 farad, 1 farad or higher? i'm also gonna be getting a digital too.. any help will be great!
DaveGS4 Aug 16, 2006 06:19 PM
I'm no expert, but probably some more details on your amps (brand, wattage) and alternator will be helpful to those who are.
I don't have the background on the 'why' on mine... installer recommended based on my setup, but know what / where they are.
http://www.somniplex.com/gallery/alb...4/IMG_6046.jpg
http://www.somniplex.com/gallery/alb...4/IMG_6146.jpg
engin_ear Aug 16, 2006 06:25 PM
IMO, don't bother with anything less than 1 farad. I have one, but I still get dropping of voltage when I crank up the system hard. The wiring impedance to/from the amps/cap matters more than the cap itself, as well as the cap's internal resistance.
BUSTN Aug 16, 2006 06:27 PM
put a optima battery in the trunk forget about the caps!!!!
Kharizma Aug 16, 2006 06:46 PM
ok so at least a 1 farad.. i'm definately doin' digital 'cause i'm doin' a custom install where i can read it.. and thanks dave - i have a factory 2000 GS4 alternator, MTX TA7801 AMP (i think) 1000W - i have factory navigation head unit, factory pioneer speakers, RF punch HE2 subs (12")..if i put a battery in the back, where would it be mounted and such? would it be better gettin' the battery vs. the cap(s)?
anyone know if i need more than one cap?
cliffud Aug 16, 2006 07:44 PM
just a thought, have you already done a grounding kit or improved the factory ground that your battery has right now with a thicker guage wire?
Kharizma Aug 16, 2006 10:19 PM
yes i have the teck kit grounding kit.
Bill_GS3 Aug 17, 2006 06:46 AM
It's been a while since I mesed with audio stuff, but, I think the rule was 1 farad to 1 thousands watts of power.
You can also find performance audio "batteries". They are not like your typical engine starting batteries, these release the power a lot faster to the amps when needed. Usually these are wired in with the stereo equipment.
-Bill
Kharizma Aug 17, 2006 08:29 AM
so getting a battery is better than just gettin' a cap?
Lexbox Aug 17, 2006 09:45 PM
Getting an HO alternator would do more than a battery or capacitors. A capacitor doesnt do much if it cant be recharged quickly enough.
Kharizma Aug 18, 2006 12:06 AM
hmm.. how much do alternators run?
Trashed Aug 18, 2006 07:12 AM
i would definatly get 1 farit or more
Bill_GS3 Aug 18, 2006 08:10 AM
There is a special battery. But depending on the power requirements, sometimes it is better. You may be best off with a couple farad worth of caps.
-Bill
vin 78 Aug 18, 2006 09:51 AM
Some of you guys should get your alternator, battery and cap straight, they all serve a different purpose. :)
Cap: provides a quick burst of power to your amp(s)
Additional battery: is only needed when you plan to listen to your system w/ the engine off, however, if you already have a weak alternator, it will now have to charge up two batteries.
Alternator: recharges your battery, I used to tell my customers that its the last resort because its usually the most expensive upgrade.
Most systems don't even need an aftermarket alternator, i'm not saying its bad to have one, but sometimes its a total overkill.
The cap, since its the cheapest upgrade, should be the first upgrade.
vin
