Aftermarket Changer install help...
Want to sell my Clarion CD changer to my buddies brother, he's got a 94 ES300. I have no clue how to do wiring, since i had a shop remove it out of my old maxima, but i will show you some pics and if anyone would know how to wire it to work with the car i would appreciate the help.
That looks like a FM modulator changer system.
1. Connect the Clarion antenna wire into the factory radio. Connect the OEM antenna into the female end of the Clarion antenna cable.
2. Connect the constant power, ground, and switched power.
3. I think the Clarion unit has radio stations switches on the control unit for the changer signals, you might have to play around with the stations so you can find the best sound quality.
That's pretty much it, It seems that there's more then two antenna wires, I'm not sure what they are for, that might be a antenna adaptor for Maxima.
Good luck with the install.
Lex Master
Jan 29, 2008 04:45 AM
