Upgrading to Nak system question
Old Apr 18, 2005 | 09:00 AM
agc's Avatar
agc
Default Upgrading to Nak system question
Hey guys I am looking at upgrading the premium system to a Nak system on my 2000 LS400. Can you guys tell me if this is worth it. I am thinking of changing the following
1. Head Unit (includes climate control)
2. Sub-woofer
3. Amp
4. Speakers (might not be able to get all the Nak speaker, so I might get Infinity, Polk or something across those lines)
Can you guys tell me if this is worth it, as well as how hard is it to change. I did some search on the forum but did not find anything relating to the 98-00 LS model. Is it as simple as changing units out and using the eisting wiring or is it much more difficult than that.
Thanks
AGC
Old Apr 18, 2005 | 09:09 AM
/Aerostar\'s Avatar
/Aerostar\
Why not upgrade to aftermarket? Id say get an entry-level Alpine HU custom mounted, with a good cheap amp powering a 10" sub, with Infinity speakers. It'll sound much better than stock or Nakamichi and shouldnt run you too much
Old Apr 18, 2005 | 12:15 PM
Percy's Avatar
Percy
Moderator - Electronics Forum
25 Year Member
Go aftermarket. Wiring harnesses are different in the Nak than they are with the Pioneer. By the time you've dumped the money into a Nak, you would have had a really nice aftermarket system. Aftermarket would sound much better too.
Percy
Old Apr 18, 2005 | 01:17 PM
Neo's Avatar
Neo
The One
Percy, do you know if the connector to the Nak and Pioneer speaker enclosures are different? I am pretty sure the harness behind the HU would be different but would the speakers (enclosure and driver) be swappable? Thanks.
Old Apr 18, 2005 | 02:54 PM
Percy's Avatar
Percy
25 Year Member
Neo,
Best guess is that the connector for the speakers on both the Pioneer and Nak are the same. You could potentially swap out speakers and if you wanted to, rig the system for entirely Nak. Expensive project.
Percy
Old Apr 18, 2005 | 03:33 PM
Neo's Avatar
Neo
The One
Neo,
Percy
Thanks. I was just interested in the speakers side. The other side would be something else.
Old Apr 18, 2005 | 04:50 PM
engin_ear's Avatar
engin_ear
Everything in Moderation
Once you go aftermarket, you'll never go back.
Not worth doing the Nak upgrade. Hey, I ripped my whole Nak system OUT, for cryin' out loud.
Old Apr 20, 2005 | 09:39 AM
Kansas's Avatar
Kansas
agc, your climate control is a separate unit and not part of the head unit - I've pulled the whole thing out of the dash more than once. The Pioneer in a co-worker's 99 LS does not sound that much different than the Nak in my 00 LS. The wiring harness connectors are different for the standard and Nak. Same number of pins but a different number of connectors - I found this out when hooking my Nokia phone's car kit to mute the Nak during a call. Sounds like a very expensive project - I think I saw that the retail on a new Nak head unit for the 98-00 was several thousand dollars.
Old Apr 20, 2005 | 01:36 PM
agc's Avatar
agc
Thanks all,
The reason I though about the conversion is because I can probably pick up the following items for about $500, maybe less
1. Nak Head Unit w/Climate Control
2. Nak Speakers (one side of the car only, I think drivers)
3. Nak Amp
4. Nak Sub
5. Nak CD Changer
platinumJZZ31
Oct 28, 2009 09:53 PM
thejtk
Aug 14, 2008 10:26 PM
taeng
Jul 31, 2007 01:41 PM
Lexs400
Oct 26, 2004 03:50 PM
stanigu
Mar 29, 2004 12:09 PM
