1990 Lexus ES250...
Old Sep 28, 2004 | 07:06 PM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
Default 1990 Lexus ES250...
hey all, new member here. i would liekl to get this HU:
into this slot
is there a dash kit or something i can use??/ as it stands right now, the cassette player in the stocker doesnt work, and i would really like to swap it out...
TIA.
Old Sep 29, 2004 | 01:37 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
anyone???
Old Sep 29, 2004 | 05:17 PM
dentpusher's Avatar
dentpusher
The radio will bolt right in and use a toyota pocket to fill the spot on the bottom. You can get one from the dealer or a local stereo shop which metra makes. The radio will have mounting spots on the side that will line up with the factory brackets as well as the pocket and the cup holder will stay there.
Old Sep 30, 2004 | 03:53 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
really??? well it looks as if i have a weekend project, im not too worried about having a hole in my dash for a few days LOL, but would it be alright to connect my HU to a factory amped system??? it is a 50X4 MOSFET Pioneer DEH1550.
Old Sep 30, 2004 | 04:11 PM
dentpusher's Avatar
dentpusher
The system in your car should have the amp down in the dash by the radio. If you unplug the amp you can use a normal 2 plug toyota harness.
Old Oct 1, 2004 | 01:16 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
heh.., there is an amp before the rear deck speakers...IN the trunk!!!! its bolted to the rear deck! weird...i need to bypas it then???
Old Oct 1, 2004 | 03:33 PM
dentpusher's Avatar
dentpusher
On a system that old you are better off. The amp in the radio will be a little cleaner and more powerful. You can run through it but will have to wire up the remote turn on wire to get sound. On the harness there are two blue wires. One for antenna and one for amp so make sure you hook them up if using the amp.
Old Oct 1, 2004 | 08:35 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
it wont blow my HU???
how much would a shop change to install my HU and run the RCA cables/amp power wire (blue one) to the trunk??
Old Oct 1, 2004 | 10:41 PM
dentpusher's Avatar
dentpusher
Running into your factory amp wont hurt you head unit. Your area prices are going to be different then here so youll have to check around.
ricandax
May 24, 2009 10:01 PM
G3Johnson
Nov 24, 2007 07:40 AM
Billy305
Oct 15, 2007 10:30 PM
jmlaudio
May 18, 2007 10:37 PM
JDMHARRIER
RX - 1st Gen (1999-2003)
Mar 6, 2006 01:05 AM
