Nav video switching
Old Mar 28, 2004 | 07:21 PM
kabrera's Avatar
kabrera
Default Nav video switching
A couple of systems showed the vlad kit, and another circuit board that was used for a component to rgb converter. In these cases whats used to do the a/v switching for the source. Since 3 wires are needed to be changed will this require some sort of a relay or component video switch.
Old Apr 1, 2004 | 04:41 PM
LS007's Avatar
LS007
In the case of the Vlad kit, the Pioneer GEX-P7000TV does the switching. It's not a mechanical relay inside the GEX, but a electronic switch. The black box in the kit simply passes video signals from the wires going into the box to the plugs going to the GEX.
Old Apr 1, 2004 | 07:21 PM
kabrera's Avatar
kabrera
so the Pioneer GEX-P7000TV does RGB switching... ?
Old Apr 5, 2004 | 10:47 PM
LS007's Avatar
LS007
Yes.. the GEX does RGB switching, but only between the red 20 pin navigation input connector and it's own composite video to RGB decoder. The RGB output is on the green 20 pin monitor connector.
08Lexus250
Feb 1, 2009 07:40 PM
QATARI
Jan 20, 2007 11:55 AM
