12V Short somewhere ?
Old Feb 19, 2004 | 10:40 AM
mlevk's Avatar
mlevk
Default 12V Short somewhere ?
Here's my problem,
My battery was discharging over a period of 3 days or so ,
so I disconnect the NEG terminal and hooked a VOLT meter toi it,
It shows a 12V draw with nothing on , I don't think that should be
the case, any experience or opinions on this? Seems that the only
thing on is the LCD clock and I shouldn't see 12V there.
Help me out if you can.
Thanks in adavnce.
Old Feb 22, 2004 | 06:16 AM
VVT-i's Avatar
VVT-i
You will need to check for draw by ampere, not voltage. The 12 volts draw alway there. Switch the multi meter to amp and disconnect the negative terminal.
Put one end to the negative terminal and another lead end to the battery. With all the doors and trunk closed, you should not see more than 0.05 mA.
edgy
Performance
Dec 12, 2011 05:31 AM
adreano17
12
Jun 14, 2011 03:24 PM
blkvip
Sep 26, 2010 07:19 PM
Rising_Sun
Aug 23, 2010 12:12 PM
bezeeduzit
Jul 1, 2004 11:19 AM
